Workbench Update
Workbench Update
Workbench Update
Stephen Kirk
Well, I have the top just about done. The two halves are both just a hair under 3" thick (as in, 1/32" under). I have to take a few swipes with a cabinet scraper to level the final glue joint - I tried to keep them very close to minimize any extra work. I think the difference is too small to warrant a pass through the planer and I doubt I can take it out of flat with a few cabinet scraper swipes. I'm about 11 5/8" wide and 84" long which is right where I wanted to be. These things are heavy, so I'm really glad this part of the build is over. Let me tell you, I can't wait to put these things in use. Coming from a solid core door bench these feel totally massive and stable.
I started with 14 planks. Glued up 6 pairs, left two. Then I made 2 sets of 4 and 2 sets of 3. Jointed and planed to keep flat before the glue ups. Then I glued up 2 sets of seven. Final trim to length on the chop saw and all was good. Long process, due to space and clamp restrictions, but it's all done. I've got a few knots and such in the boards so I picked up some System 3 Epoxy to fill them - they'll never move.
Re: Workbench Update
Gary Smyth
If you're not adverse to some help and reasonably close by one why not glue them up fill them and take the completed top down to a millwork shop with a wide sander. A single pass or two little ones with a fine grit will get them flat across the width and length. Shop time will likely be less than fifteen minutes.
