Cutting siding
Dustmaker Mike
Well while I was watching a pro cut siding I discovered the correct way to do it. So I copied it. It works great and is a lot better then cutting the siding by hand shears.
Cutting siding
Dustmaker Mike
Re: Cutting siding
Moses Yoder
You are pulling the saw through backwards, aren't you?
Nope
Dustmaker Mike
we are using a vary fine tooth blade and this is really thick siding. Charter Oaks this stuff does not bend at 12 feet in length it just sort of bows. Now if I was using the stuff from the Borg I would have turned the blade around.
Re: Nope
Nelson
Why would you turn blade around? I have cut Hardie board without turning blade around,should I have?
Re: Nope
Kevin MacLuskie
Not with hardiboard, no. When you're cutting thin to medium weight vinyl siding, if you need to turn a generic multiuse blade around, or else it will break out chunks, and make a mess of the cut. Using a fine tooth plywood blade, you can often times use it normally. Although like it was mentioned before, if you're using really thin stuff from the borg, I'd even turn a fine tooth blade around backwards.
You can use a 12" miter saw with the blade turned around backwards too. Works nicely for straight cuts.
Re: Cutting siding
Michael Wilkins
I did the exact same set-up several years ago for a sunroom add-on. A carriage-like device that housed the saw platform, using a cheap plywood blade turned backwards. Saw the backwards blade trick on an old episode of This Old House. Worked better than any store-bought fixture I could have purchased.
Re: Cutting siding
George Koch
Probably revealing my true age here, but aluminum siding manufacturers use to supply their installers with a similar saw table and a saw that rotated in reverse so the blade was mounted backwards and the teeth would cut downward into the siding. George
Re: Nope
Nelson
Thanks for the info.
The golden age of siding sales
Tom Dunlap
Tin Men is a great movie:
http://www.imdb.com/title/tt0094155/
If you watch it, pay close attention to the closing scenes...look on the far horizon many blocks away. What is the crane swinging into place? The next franchise frontier!
