way OT calculus problems
Thomas S Stockton
My son is taking an online calculus class and the following two problems are driving him crazy. He has a tutor helping him but he is stumped also. I'm a furniture maker and haven't had a math class in 30 years. Mostly what he is looking for is direction on how to solve the problem. The second one has an answer since it is an odd # question but they don't show the process. Since it has all sorts of symbols I'm just posting a pic of them
Thanks
Tom
Re: way OT calculus problems
Problem #1 solution
Rich Pearson in Mill Creek, WA
Since y =the positive square root of (2-x squared) AND x is between 0 and 1 inclusive, we know that the solution MUST be in Quadrant I .
Square both sides of the equation and the result is :
y squared = 2 - x squared
Add x squared to both sides and you get:
x squared + y squared = 2
This is the equation of a circle in standard form which is centered at the Origin (0,0) with a radius = the square root of 2 .
Graph the equation and apply Circumference = 2 times pi times radius
which yields a circumference of 2 times pi times the square root of 2 for the whole circle.
Since the solution is only in Quadrant I (i.e it's a quarter of the circle), you need to divide by 4 .
this gives you a result of (the square root of 2 times pi ) divided by 2
(I sure wish I knew how to type exponents on this forum!)
I'm very rusty on problems of the type of #2 but would suggest using a graphing calculator to look at the "picture" of the equation to get a hint as to it's shape and a solution may suggest itself.
Actually....
Hoa
I asked my son David. He was busy preparing for his final next week so he couldn't spend much time with the problems. But he told me there was a general formula.
Choose a parameter t so that x = f(t) and y = g(t).
Arc length from a to b is the integral from a to b of h(t)dt.
h(t) is this function of t: square root of { [f'(t)]^2 + [g'(t)]^2 } (^2 means "square")
The trick is to choose f(t) and g(t) so that the integration of h(t)dt is simple.
My calculus is very rusty. Sorry I can't be of much help.
Re: Problem #1 solution
Rod Peterson�Ormond Beach, FL
Easy. Just use an HTML command called an "entity." There are dozens of them available, including ² and ³ (you can look them up online—there is even a chart buried in windoze somewhere). Not every possibility has an entity tag, but there are lots of useful ones I use all the time (such as the "em dash" in the preceding parenthetical).
Specifically, to make the ² and ³ you type an ampersand (&) plus sup2 plus a semicolon (;) thus & sup 2; (without the spaces) or in the case of cubed, substitute a "3".
I use such things as an ellipses (…), approximation (≈), times (×), fractions (¼, ½, ¾), trademark (™), registered trademark (®), copyright (©), euro (€), pound sterling (£), yen (¥), cent (¢), degree (°) regularly, so I don't even have to look them up.
Also available are various language diacriticals (ñ and Ñ, è, È, é, É, ê Ê ë, Ë ¡, ¿) including the whole Cyrillic alphapet and many math operators.
Here's a place to get started.
Rod
NB: if you use any entities here at WC, AND you preview your message (and I always preview when I use entities), it's wise to back up from the "preview" before hitting "post". Sometimes the entities get retranslated if you "post" from "preview" and don't come out right. It's a feature, not a bug, and DAMHIKT. H/T to Dave Arbuckle (where's he been, now that I mention it?)
Dave MacLuskie
My take on problem #1 in the attached photo. I could be off though! My other thought is that there are TWO sections of arc where x is between 0 and 1; quadrant 1 (positive y values) and quadrant 4 (negative y values). That would effectively double the answer in my attached diagram.
Problem #2 is missing a rather critical value: you don't know where the arc ends! Also, unless it's written wrong in the scan, it's not a circle, so this solution won't work.
Re: way OT - If no one is able to give you
North of the Border
what you are looking for here, try asking Dr. Math:
http://mathforum.org/dr/math/
A team of volunteers works to help other math students. (I would have been able to help 35 years ago. haha.)
Larry Barrett
You can get an idea of what the curve in Prob 2 looks like by plotting a few points. Pick easy ones - for example, when y=0, x=0; when y=3, x=0. When y is between 0 and 3, x is negative. When y=9, x=6. So it looks a little like a parabola, but the curve is not defined when y<0 because of the square root.
If you Google "arc length" and read what you find in Wikipedia I think you can solve this problem. The basic idea is in the note from Hoa (and Hoa's son, David). Try y=t�, x=1/3(t�)- t� (thanks Rod).
Oops - last equation should be x=1/3(t�) - t
Larry Barrett
and the missing upper limit works out to be 3 (given the answer is 32/3), I think.
Joe Dugan
I'm assuming that your question is really "How can I solve this using calculus?"
I'll write up the answer and post it. I wish I had my tablet with me. One sec.
Joe Dugan
Sorry about this... I saved the answer in a gif file... and I don't have time to figure out how to post them.
I emailed the answer to dad (Lee Schierer). I'm sure he will post them.
Oh, I also assumed that this was a early question out of a Calc II course. So these questions are meant to be introductory level questions for arclength. That means no fancy integration techniques or parametric equations.
This means the answers are not ellegant, but you will be able to understand them using Calc I only.
The answers can be much cleaner and faster with a small subsitution (sine or cosines), a clever subsitution ( use a square root subsitution), or change everything over to plane curves using parametric equations.
Hi, Rod
Dave Arbuckle, Plano, TX
Been on a bit of hiatus. Thanks for the mention, I'm not sure I would have remembered that preview trick.
Thanks, Dave for your
elegant presentation (and correct ) correction to my post. I probably shouldn't attempt to do any more math problems in the very early AM whilst under medication! I blew the correct domain adjustment.
I am interested in the software you used to display the color graph and handle the math notations. What package did you use? It reads very well and the graph (on graph paper no less) is very precise.
Problem Solutions
Lee Schierer McKean, PA
Here are the answers to the two problems as determined by my math professor son in law.
We have a winner!
...Most complicated answer ever on WoodCentral! Congrats!
Actually I could have gotten that answer about 40 years ago. Thanks for the flashback.
Boy, howdy!
Wow, how did you ever find an almost off handed mention of yourself in an obscure thread when I'm not very active myself around here?
Sure is great to see your voice. Too many old friends have drifted away. Hoa Dinh, of all people, popped up earlier this week (and in this thread). I'm embarrassed at the number of people that I remember (and miss) that I can't even put a name to.
Rod
Re: Thanks, Dave for your
Dave MacLuskie
Thanks Rich.
Upon further thought I think you were correct about being restricted to quadrant 1.
The software package was Adobe Illustrator -- a rather old copy. When I was a graphic artist it was my main go-to package. The symbols are actually just hand drawn because it was faster for me for something this small.
For just equations, this link is pretty handy.
http://www.codecogs.com/latex/eqneditor.php
It provides a graphic for whatever you type in. The text version is ugly, but the graphic is quite nice! Microsoft Office use to come with a little app called Equation Editor that did something similar.
As someone else pointed out, my solution is probably not desirable in this case. I don't think it counts as a calculus solution. I'd be curious what the official method is!
