Problem with Inca Jointer/Thickness Planer
Ralph Lipeles
I have an Inca 343.190 combination Jointer and Thickness Planer. It was purchased in 1984. I got this unit as part of a workshop that I purchased. It has been sitting in my shop for a while and today I tried to use it for the first time as a thickness planer. I was not successful. The inpfeed and outfeed rollers did not work in either the high speed or low speed setting. I removed the belt access cover and was surprized to see that the worm pinion rotates properly but just bounces around on the worm gear that it is supposed to be driving. This model is the one where the worm pinion is driven by a flat belt. However, there doesn't seem to be any tension to hold the pinion against the gear that is supposed to be driving. When I looked closely at the setup, with the flat belt pulley so low, I can't see how there would ever be any tension to hold the pinion against the gear. What am I missing? Any help or ideas are greatly appreciated.
Thank you,
Ralph Lipeles
