Re: How To??
Grant in Iowa
I made a bed with those hooks. Here is how I cut them:
I tipped my Radial armed saw so the arbor was perpendicular to the table. I added an auxilliary table such that the blade could be brought into alignment with the desired cut line on the end of the bed part. I locked all movement on the saw arm.
I made a robust fenced table on the right side of my saw so the blade was rotating TOWARDS the fence, thereby preventing the workpiece from being pushed away from the fence. Atop this fenced table I laid the part. I set up stop blocks so I couldn't cut too deep. I installed a ripping blade of the right diameter and thickness into the saw.
When I was sure I would have no movement of the part except left to right, I slowly fed the part into the blade. After careful preparation, the cuts went very well.
The key is to control your cut and feed slowly. I should add that I needed to adjust the setup for two of the cuts, since they were mirror edge versions of the first two cuts.
While that worked for me, several folks here expressed concern at the time about the safety of the cut (though I am not sure exactly why). Apparently any time you use a radial arm saw, somebody cries unsafe.
So, in the interest of appeasing those folks, I offer another solution. You could also make a jig to hold a circular saw at the right point on the end of one of these boards. Again, control everything except the plunge portion of the cut, then make your cut. You could also actually clamp the base of the circular saw to the jig for added safety. This same jig could also be used to make appropriate cuts in the bedposts.
You will also find that a certain diameter and width of blade will make the proper cut possible in just a plunging motion. Too small a blade and you will need some forward motion as well, too large and it will not cut deep enough without emerging from the sides of your part. If I remember correctly, I used a 9" thin kerf blade.
Yet another option might be to use a bandsaw to create the appropriate kerf in your part. Then glue some blocks in place to hide the sides of this cut. If you have a tall enough ceiling over your table saw, you could also create an oversized tenoning jig type arrangement to make a similar cut.
Depending on your hardware, you might also be able to use a biscuit cutting tool to make the cut, though in my case that cut wouldn't be deep enough for the hardware I had purchased.
Many ways to make that cut, just think outside the box, but also spend an appropriate amount of time controlling your part or tooling in order to ensure you can do so safely.
Regards,
Grant in Iowa
