paint brush cleaning question
Bill Tindall
For me, this is particularly a problem with latex paints. Say for the purposes of this question one dips the brush into the paint 2". At the 2" line on the bristles a layer of partially dried paint develops (especially at the rate I paint). When it is time to clean the brush this band of partially dried paint at the 2" mark is particularly difficult to remove. This problem is so annoying I suspect professional painters must have figured out a way to better clean it or avoid getting it. What is the best way of removing this band or preventing it from forming?
I clean by rinsing with lots of water whilst working the bristles, then hot water and combing. The combing eventually pulls this rubbery paint out of the bristles, but it takes a long time.
Philosophically, I buy the highest quality brushes and take care of them, so this cleaning thing is important.
If you want the brush to hold more paint, you need to get the bristles to separate, which you can do by tapping the tips of your bristles on the inside wall of your paint bucket after you dip. If you need less, tap the sides of the bristles; (almost) never scrape. You also shouldn't have to dip more than 1/4-1/2".
