Follow-up on Jet dust collector motor problem
Paul Blackwell
The motor expert that is a friend of the repairman that rewound my dust collector motor was finally able to come out this morning, and I'm so happy to report that he finally found the problem. He was a very methodical (and knowledgeable) man and he began gradually eliminating sources of the noise. Since I had the spare motor for parts, we finally agreed that we'd remove the rotor and shaft from the old one and try it in the rewired one to see if that stopped the noise. He called the internal part of the motor a rotor, and I guess that used to be called an armature when it was the wired type. At any rate, when he removed the rotor from the repaired motor, he found that the shaft instead of being tight to the rotor actually freely turned. He said sometimes the shaft is spot welded on both ends to prevent turning, and sometimes is a press fit. We put the rotor and shaft from the spare parts motor in, and it worked beautifully. Thanks to one and all for the replies and advice.
