Laminating to endgrain *LINK*
mdclor
I have made a 14.5" square by 1.5" thick for the top on a Roycroft trapezoidal magazine stand. I was not able to get any QSWO that was this thick, so I laminated the top using 3 boards across and 2 boards thick.
Obviously, the end grain doesn't look like it was made from a single slab (or even 2 boards) so I would like to do something that would look better to my eye. If I glue a 3/32" veneer face over the end grain, will it hold or will the seasonal movement of the top cause problems? The plans I have found do not have veneer on the ends and I assume that is for a reason, but since QSWO is very stable and since I live in the high desert where the relative humidity ranges between 18-69% (usually the shop stays between 30-50% RH) is there a way I can successfully cover the end grain?
Any thoughts or suggestions will be greatly appreciated.
TIA,
Merle
Stickley Magazine Stand
