Door hinge pin
Door hinge pin
Dale Lenz
Door hinge pin
Dale Lenz
Over the years of my life I've noticed some door hinge pin tend to "ride up" in the hinge, what cause that? Maybe lack of lubrication. A simple tap with a hammer pushes the pin back down. Most have been the brass/brass plated door hinges but not all.
Re: Door hinge pin
Re: Door hinge pin
FredD
I would guess since up is the only direction the pin can travel when it is squeezed by the hinge knuckles when the door is moved , that would explain the travel.
On the other hand it may be a mysterious force at work, leading to conspiracy theories and legends.
FredD
Re: Door hinge pin
Re: Door hinge pin
Keith Newton----Little Rock, Arkansas
Well, if you want another Newton theory, I would guess that it probably has to do with the two leaves fairing outward at the top slightly, along with the tapper on the bottom end of the pin. Since the action of opening and closing of the door is a back and forth dynamic, this could cause a wedging action with an upward force.
This is only a theory, but it could be proven our with testing, or careful measurement by you. If you have a hinge that you are sure this has occurred to. Take a caliper or micrometer, and measure the diameter across the bottom two pin fingers, and the top two leaf joint.
Of course the difference will be limited to the difference between the ID, and the OD of the pin, even though the slant of leaves and screw pressure could be greater. It may be worth taking out the pin and re-measuring if there are more than two hinges. What do you think? Are you curious enough to do this?
Re: Door hinge pin
Its An Open And Shut Case
George Colonel's Workshop-Havertown PA
Good Morning Dale,
Thorough Evaluation may engender wide swings of opinion.
George
Re: Door hinge pin
Re: Door hinge pin
Marv
Hi Dale,
My guess is, the hinge that is moving it's pin up is due to it not being in alignment with the door and the door jamb.
Try removing the pin, then when you push it back in, observe if it binds as you push it in. It should push in with even pressure.
Lubrication will of course reduce or eliminate the problem.
Marv
Re: Door hinge pin
Colonel, you have such stile!
Every time someone gets in a jamb, you have an uplifting comment to make.
And you never make the person asking the question the butt of your humor.
Re: Door hinge pin
Subtle misalignments of the hinges
And, yes, since up is the only way the pin can move, it will.
Two cures:
1. Take the pin out and, setting it on two blocks of wood so that the middle is hanging in the air, tap it gently to introduce a slight curve (SLIGHT).
2. On many hinges, the hinge pin hole is slightly smaller on one leaf than on the other, so that the pin is held in place but the hinge will open freely. Confirm that, on your hinge, the leaf with the top hole (as it's assembled) is the tight leaf. If so, take out the pin and make a couple of dents in it with a center punch, up toward the top where the pin will be resting inside the tight leaf when installed.
In both cases, reinstall. I use Vaseline for hinge pin lubrication. Works fine, most houses have some, doesn't stain paint or people (and it allowed me to awe my brother once, when we were working on a squeaky door near the bathroom at my parents' house - the solution was five steps away).
Re: Door hinge pin
Can't Rail Against That Observation, Bill
Re: Door hinge pin
"The Bigger Hammer Theory"
Basil
And they say fire and the wheel advanced civilization...haw.
Re: Door hinge pin
Dale Lenz
Thanks for the responses, atleast most of them,:")
Dale Lenz
Will use the vasoline or other lub. next time I have a hinge pin trying to escape.
