What would hold up for 4 months??
Frank on Chestnut Hill
Gentlemen,
Making up some elections signs and have the choice of using OSB painted with an exterior paint or Tempered hardboard painted with the same exterior grade paint. Which would last for 4 months?
Thank You, FFG
Re: What would hold up for 4 months??
David Barnett
Well, I'd say...
David Barnett
...oriented strand for Democrats and tempered hardboard for Republicans. Apply paint liberally... or conservatively, as appropriate.
Re: Well, I'd say...
Construction plywood (OSB) is supposed to stand up to six weeks in the weather to give you time to get the house under roof. Depending on your climate and how well you seal it, I might be possible for it to make four months in good shape.
Tempered hardboard probably wouldn't make it as well. Does not stand up to water well.
Also look at Zip System plywood. Its coated with orange or green "paint". Seal the edges well and I think it would make it.
The last signs I had anything to do with were on some sort of corrugated plastic sheets. Sort of flimsy but plenty durable.
The prefered material is MDO. Good stuff but not cheap.
Try to find some MDO (EOM)
Grant in Iowa
But, if you already have the Tempered hardboard, I'd go with that making sure to coat it 100% including the edges with paint.
FWIW,
Grant in Iowa
FredD
OSB is Oriented Strand Board, not construction plywood .
When I built my camp,
Keith Newton----Little Rock, Arkansas
We didn't have a lot of money, so I was looking for a low cost siding. A carpenter friend had good things to say for a T-111 type siding made from a fiber material. It may have been a masonite product, but I got a sample, and soaked it in a bucket of soapy water for two days, then put it in my coffee beaker for two cycles of just boiling water.
The penetration was only 1/16" after that. It was $11 per 1/2 x 4 x 8 in 2005 at HD. It is pre-primed, which is still the way it is after 5 years, in a very damp environment. Although I think I may need to paint it in a few more years, there is no edge swelling or other problems, which you will only improve with the painting of your ad.
Oops, Mixed my metaphors.
Perhaps I should have said "Construction plywood or OSB, or sheet products such as construction grade plywood or OSB as opposed to cabinet grade materials intended for interior us only are fabricated in such a fashion to be exposed to the weather for six weeks."
Or maybe, maybe "what passes for construction grade plywood including Oriented Strand Board (OSB)...."
In a way OSB is plywood. In the earlier version, Waferboard, the manufacturers assumed the wafers which were generally roundish would randomly orient themselves and that would impart plywood like characteristics to the sheets. It turned out that was not satisfactory and the sheets were inconsistent, so they developed OSB where the chips are generally longer than they are wide and there are several layers or plays where they are mechanically oriented north south and east west similar to plys in plywood to assure they have enough correct orientation to give the sheets reasonabley consistent plywood like characteristics.
Gary Smyth
http://www.justyardsigns.com/?gclid=CKujwLuH8KICFRY75QodOCytig
Why waste the time. Corregated plastic is the better way to go. It will hold to the waether and are light in weight. They look "professional". Just make sure the backgound is dark or a moving car will not be able to read.
Tempered hardboard
comes in several grades. The highly tempered stuff, which is dark chocolate brown (roughly like a Hershey bar, though not as tasty), holds up to weather quite well. I used some as the finish roof on a woodshed for more than ten years, and it worked just fine. It should shrug off four months no problem.
The more lightly tempered stuff isn't much different from untempered, in my experience, except that it's more brittle.
