Need more hot air....
Marv
Hi Folks,
I have a couple small tubeless tires on a small John Deere trailer that have gone flat. They are about the size of a wheelbarrow tire. There's a gap between the tire and the rim. My small compressor isn't big enough to pump enough air in fast enough to seal it. I attempted to close the gap with bungee cords but to no avail.
I've seen on Youtube how propane or similar gas can be injected into the tire then lit to make it explode which pressurizes the tire. This method makes me a bit nervous, having never done it. On Youtube, they were doing it with large truck tires. On a small tire, is it possible to put too much gas in the tire and blow it clean off the rim?
Anyone ever do the gas thing? Is there a safe way to do it? What precausions should taken? Is there another way thats easy for an old f**t like me to compress the outer circumference of the tire to get it to close the gap without using gas?
If the gas method is used, do you just leave the gas in the tire? or bleed some off and replace it with air?
Thanks,
Marv
