Re: Air compressor question
Al Stokka - Cambridge, Iowa
North,
I'm glad I'm a pack rat...saves retyping since the Badger Pond post below, from March, 2001, answers your question (and then some):
I called Ingersoll-Rand and asked about leaving the tank pressurized as relates to tank life and warranty. The answer: "Makes no difference." So that variable is out of the equation. It is important, however, to remove the water from the receiver as it accumulates.
No need to drain the tank after every use under normal use and normal atmospheric conditions. In fact, doing so is counterproductive. If you drain the tank, then at the next use the compressor will first have to fill the tank with air. Along with the air goes the ever-present water in vapor state. It is much better to leave the tank charged with air and bleed off the water via the drain petcock as it accumulates.
Experience will quickly teach you how often to remove the condensed water vapor. Start by opening the petcock at the end of each shop session during which you used the compressor. If you find that you are releasing only air and no water, try every other session. Then every third, etc. until you find water.
Your assumption about the amount of water accumulation being dependent on the relative humidity is correct. As the moisture content of the air increases, so will the amount of condensate in the compressor tank.
Another factor that determines the amount of condensate is the temperature of the tank. The more you use the compressor, that is the longer the compressor pumps air into the tank, the warmer the tank becomes and the less moisture will condense. The moisture doesn't disappear, of course. It simply exits the end of the air hose along with the air.
A second benefit of leaving the receiver under pressure is that the air in the tank has time to cool. Cooling will cause additional moisture to condense and accumulate to the point where you can drain it.
Benefit three: Leaving the tank pressurized uses less electricity (assuming your entire system is leak free). Collect all that saved electricity in a coffee can and send it to Sophie. ;^)
Al
