Face frame widths
Face frame widths
Face frame widths
Bill Tindall
For years we sold hardwood to local cabinet shops so I have some insight into their practices. Without exception they all made face frames 2" wide. Yet in response to a question below two people experienced in construction in other places advocated 1 1/2" widths. Is face frame width a regional thing, or was the suggestion of the narrower width a personal preference for looks?
Re: Face frame widths
I like them narrower myself. It's not really "regional", it is probably because I do a lot of bookshelves that are mixed with cabinets (cabinet lower portion and bookshelves above). You can "lose" a book behind a wide face frame on a shelving unit. If you do them narrower - the cabinets "echo" the shelves.
Larry
I've been macking mine 1 3/4 for years.
Larry
Construction technique is one variable...
John in NM
My view of it is probably skewed a bit by having always built inset doors and drawers for kitchens. Go with overlay doors, which I believe are still the prevailing industry standard, and you need more width to have the same amount of frame showing. So I don't think its regional so much as in these two groups (forum posters vs. commercial lumber buyers) you're seeing very different segments of the woodworking world.
Re: Construction technique is one variable...
I am trying to remember, but I think the horizontals were 1 1/2" and the verticals were 2". One reason is that the hinges were often the offset hinges for overlay doors. If the verticals were narrower, the hinges would have hit each other.
FredD
Anymore with onset of European Cabinetry you could see anything from a wide stile to little or no stile showing,
Using traditional face frame practice , you rarely see any stiles less then two inches in width or wider then 2 1/4 "
That is the range I stayed in for several reasons .
Excluding all of the special size stiles and ones wider then normal or narrower,because the shop owner was not trained in a Union shop and didn't know better, the stile width can vary slightly to accommodate a more pleasing layout , it can be called out on a AIA set of plans or if made to conform to a inspection service like Wood Institute of Ca.
Some Interior Decorators and at least one Developer I knew , liked to meddle in the choosing of whether a pair of doors closed on a stile or each other and even issues more silly then that , like deviating from standard heights for upper and lower cabinets.
Then the more obvious reasons like a stile width that will accommodate 3/8ths offset lipped door hinges or 5/8ths overlay doors and Biscuit or MT face frame assembly come into play.
As Bill pointed out , his shop clientele marched to the same beat .
Cabinetry ,particular in Kitchen and Bath cabinets, has been standardized for sizes in every dimension for a long time, before me for instance.
It is not a regional thing USA wise , you would need to look at another country for substantial differences in design and assembly.
The German approach to Kitchens comes to mind, where you buy a large cabinet called a Shrunk and you take it with you when you move.
FredD
Moses Yoder
Moses Yoder
We have always made our face frame widths 1-1/2" because it is not too wide and not too narrow :( We use a 1-1/4" frame with a 5/16" bead molding added to it when the doors are beaded full inset. A 2" wide frame looks clunky in my opinion, with a 1/2" of wasted space on each side of the opening I guess. A 1-1/2" frame holds 2 dowels spaced 3/4" apart very well and is plenty strong enough for kitchen cabinets.
Charles Jackson III
I was taught to use 2'' face frames. I dont know if thats a rule or not.
