morris chair
morris chair
morris chair
tom
im making a spindle arm morris chair . are the spindles on the side of the chair suposed to be 1/2 or 3/4 square . my plans are unclear in that they say one thing and show another .it shows foot stool at 3/4 and chair at 1/2 wich to me would be backwards at best . i woul like to know wich size is true to the stikley original for the stool and chair .
thanks
tom
Re: morris chair
Mr. or Mrs. Morris?
This is a "Lady Morris" chair in cherry from a Stickley original. .
The spindles are 1/2"
The Stickley Prairie sofa I did
uses 3/4" spindles as does the full-size spindle-arm Morris chair.
Check your plan as you may be reading the spindle mortise spec. The 1/2" spindles need a 1/4" hole and the 3/4" need 1/2".
hth
Re: morris chair
Re: morris chair
Bruce, a MN Galoot
I'm not sure of the original, but I've made two Morris chairs, both from the same plan in FWW maybe 14 - 15 years ago, and that plan called for 3/4" square spindles. Lots of them.
Re: morris chair
PS
The spindle footstool for the full-size Stickley Morris takes 3/4" spindles so long as your stretchers are more than 3/4". The design needs the resulting shadow line.
Re: morris chair
Re: Mr. or Mrs. Morris?
Charles Jackson III
Nice work, Mike.
Re: morris chair
How many Morris chair designs were there?
Keith Newton----Little Rock, Arkansas
A friend ask me about looking at and doing a small repair to one that has been in an old log cabin he owns out in the boonies. I got it yesterday, and it has turned fluted front legs, and only 4 turned spindles under the arms.
The foot rest slides out of a slot under the seat, not an ottoman.
I'm sure this one has the original finish, which is crackled. The wood has a very fine diffused open pore, and even texture, no annual ring.
I have been searching for a catalog that might show this one, with no luck, but it does have the Morris label on it.
Re: morris chair
Clint Searl
Re: How many Morris chair designs were there?
Clint Searl
The basic design lends itself much room for poetic license, so I think that every manufacturer offered their own interpretation, maybe several different ones.
Clint
