Plywood Coating-smooth the grain.
Nick Barnes
I have a client who is looking for some 12" and larger cubes to use as props in a photo shoot. I built him some out of B/C sanded plywood and primed and spray painted silver. He says that the grain is still showing thru and doesn't look good on film. He in turn has a high-end clothing client and they are looking for a smoother finish. Oh yeah, his shoot is on Monday the 12th. Thank you in advance for any help with a better method/coating.
Thanks,
Nick
P.S. He is looking for a more satin finish rather than mirrored.
Re: Plywood Coating-smooth the grain.
paul in AZ
How about facing them with a formica-like surface? You could cement this onto the existing cubes.
Plastic laminate was my thought also. But there are a few bucks involved and a learning curve if you have never worked with it. Fast and easy if you are up to speed, but not so much if it is unfamiliar. The edges might be a problem. They can be pretty contrasty if they don't match the surface and might stand out in the pictures.
I also wondered about coating them with something as simple as brown paper and then painting it.
Also, You might just have a painting problem. If you could prime them with something like gesso or even latex primer, sand and paint, you might be happy.
Gary Smyth
Since it's for a photo shoot, it doesn't have to be a (solid) cube. It could easily be a frame w no sides. Or maybe only some are cubes. In a two dimensional shot only three sides of a cube will show in most any configuration (unless a mirrored background). Depending on the set you might be able to get away with a frame with a painted canvas covering. (Are the cubes identical?) Laminate is good to fix what you have but you have to find solid color throughout for the edges or a matching paint. What color did he ask for? If it's black you have a break -- but even that depends on the lighting. Given the time you have, paint may be the only way to meet deadline. Most stages would use canvas because of weight and foldability. The canvas weave can be filled smooth. If a partial cube canvas can be stretched over the frame of the cube and stapled on parts of the frame not showing. If someone is going to sit or stand on them then a full cube with solid sides is the only option and a "sand" wall finish can provide dullness and grip. You could also use body filler but the effort and dust would not make it profitable.
Phil Joines
In the future why not use MDF ? No grain. Both HD & Lowes here carry 3/4
If they hadn't been painted already I'd use several coats of sanding sealer, sanded smooth, then a coat of spray paint.
Kilz to the rescue
Bill Tindall
The oil based stuff can be coated at extreme thickness as necessary and sanded glass smooth.
Kneale Brownson
Glue on floor tiles--color goes....
Kneale Brownson
all the way through so edge contrast would be minimal.
Re: Plywood Coating-smooth the grain./SPACKLE! NM
Justin Szeliga
