Question, Ellis on bandsaw resaw blade
Bill Tindall
Below you mentioned you resaw with a 1" 2-3 blade (I presume Lenox?) on a 20" wheel. There has been some question as to what blade thickness a 20" wheel will accommodate. I would presume a 1" blade would be the thicker 0.03X" (I can't remember the 3rd decimal place), yes? It does fine?
Re: Question, Ellis on bandsaw resaw blade
Gauge v. wheel diameter
Yes, Bill, my 1" blades are .035" thick and do fine on a 20" saw. I have never had one break because of metal fatigue, which would be the issue if the wheel diameter were too small for that gauge of steel.
removal of last impediment
Bill Tindall
I have been considering purchase of such a blade, Lenox, but had some concern about the thickness being on the edge of what a 20" wheel would accommodate. Now I just need to get a line of credit established at my local loan office and go order one.
Re: removal of last impediment
David Yoho
Bill, for what it's worth, I've been using a 1" Lenox carbide blade on my 16" Mini Max for years without a problem. Granted I don't run it every day but it has been fine. I do remove the tension on the blade every time I finish working with it. There was debate at the time I bought mine as to whether it would work. The Mini Max folks said it would and, so far, they've been right.
David
