OT-Computer Question
Thomas Norton
Hi,
My husband wants me to post an ot question regarding sending his woodworking invoices via attachments to an e-mail.
Occasionally it works but most of the time I get a message that says "file not found" check routing address. I make his invoices on the Excel program. I don't know what I'm looking for the check the file location. I find the file in my documents folder where I put it when I made the invoice. I click on the file name I made...shouldn't that be enough?
At first I thought it was the finickiness of gmail but I tried it with my yahoo account and it does the same thing.
Kathy (wife of a hardworking cabinetmaker/woodworker)
Re: OT-Computer Question
Something is amiss...
Usually computers are pretty reliable if they report that they can't find the file. In Gmail, I'm assuming that you're going to the send mail form, filling in the recipient and the subject and then attaching the Excel file of the invoice. When do you get the "File not found" notice? If you click the "Attach file" link and navigate to an existing file in Windows Explorer, it should find and upload that file, no questions asked. If the Explorer shows that the file exists, I don't understand how you could get a "file not found" message, ever.
Can you provide any further information about how you're doing this? To create the invoice, are you opening an Excel template (.XLT file) and then filling in the charges and saving the file as an .XLS document? If so, and you can navigate to it through Gmail's "Attach file" link, you shouldn't be having this trouble.
Very curious. Wish there were an obvious answer.
Ellis Walentine, Host
Dave (PacNW)
Hi,I don't know what Email program you are using, but with the two I use it works this way. 1) start your new email 2) click on attachments 3) navigate to the file you want to attach 4) double click on the file and it should show as an attachment to your open email I hope this helps!
Dave (PacNW)
David Hay Denver
Are you getting the error when you try to attach the file or when you send the email? If it's the latter, it's possible the email host on the opposite end is rejecting emails with Excel attachments because it thinks they're spam and/or spyware. You might look into ways to convert the Excel spreadsheet into a PDF file. I can't remember if Excel has a built in way of doing this or not.
David
BrianA from Monument
I once upon a time had a problem that sounds like this one.
The problem was that i was working on the doc I was sending just before sending it.
My lesson learned was that I needed to save and exit the program that made the doc.
Then attach it but AFTER closing the program.
My 2 cents.
