Looking for a portable sawmill operator
Phil Joines
A friend is looking for a commercial portable sawmill operator in the Ardmore, Ok. area. I've alredy emailed the various manufactures but haven't heard back from them.
Re: Looking for a portable sawmill operator
Dale Lenz
Dale Lenz
Contact Kevin Keys, Oklahoma forester that covers that area. Email: kevin.keys@oda.state.ok.us
Good luck
Phil Joines
It only lists 4 in all of Oklahoma. You'd think there'd be more, after all they have real trees up there.
What do these folks charge...
Larry Wyatt
and is it better to have them bill by the BF or by the hour?
Thanks.
Larry Wyatt
aka Cole's Dad
Re: What do these folks charge...
Depends on whether they're coming out to your site to do the sawing or if you're taking the log(s) to them. I used to have on-site sawing done for $35 to $45 per hour, but that was a while ago and in different economic times. Paying by the board foot is trickier, as heavier lumber requires less labor to cut the same number of board feet as thinner lumber. So you have to discuss the options with the sawyer. Some are willing to go either way.
Phil Joines
I don't know any portable operators but Woods of Mission Timbers in Sanger Texas has a mill, kilm and sales operation. Last I heard charged $90 per hour. You have to deliver the logs and pickup the boards yourself. I think it would depend on the personality of the operator weather per hour of board foot would be better. Some would work harder than others.
Are there trees in Oklahoma?
Hank Knight
I never saw a tree the whole time I was at Fort Sill. This thread has given me a new perspective on the Sooner State. :D
Way more than here  :>)
Phil Joines
Grant in Iowa
Larry,
In Eastern Iowa, my sawyer runs a 1993 Woodmizer band mill. His rates are 30 cents per board foot for 4 and five quarter lumber. He charges $1 per mile travel charge (one way distance times $1). if his blade dulls through normal wear and tear, there is no cost, but if he hits foreign objects I pay for the blade or its repair if it is a minor hit such as a small nail. I believe this rate includes my help offbearing the cut lumber and slabs.
I have not asked for it, but I believe there may be a slight upcharge for quarter sawing.
I prefer the by the board foot charge method as it incents the sawyer to get as much lumber from the log(s) as possible.
You want a sawyer with a lot of experience. There's more to it than running the mill through the logs.
If you goodle "woodweb log volume calculator" and "woodweb log weight calculator" you can see what your proposed logs may yield and weigh. Use the Doyle scale, small end diameter, and add about ten percent for a bandmill.
Not all logs make good sawlogs, and it is hard to tell a good sawlog from a bad one. Look for logs with no major limbs to start with. End seal the logs with either latex paint or green wood sealer like Anchor seal.
Moving logs takes experience, the right equipment and a careful and diliberate demeanor to do so safely. They weigh a LOT. Don't go to the woods alone for safety's sake. If you have two or more logs it is probably well worth it to hire the sawing to be done at the site where the logs are located.
I can go into methods for moving logs if you like.
Regards,
Grant in Iowa<-- just stickered and stacked another 1050 board feet of Walnut, hickory, and Red Oak...
Here's a motivating photo
Grant in Iowa
Here's the most recent stack of lumber. Just stickered and stacked a couple days ago. Five quarter Red oak and 4/4 Walnut on the right. On the left is Cherry at the bottom and Hickory on top.
Kneale Brownson
Kneale Brownson
Guy who sawed up a bunch of logs at my site last summer charged me 25 cents a BF.
Larry Wyatt
Thanks, everyone for all the great information!!!
Larry
Hummmm, Those longer boards,
Keith Newton----Little Rock, Arkansas
higher up in the stack should have an adjustable prop under the ends. As the wood in the stack dries, it will become thinner, causing the prop to be too tall, which appears to be showing up in the photo.
Re: Here's a motivating photo
FredD
While you have those nice stacks Grant and can get to them easy , get some AnchorSeal and do the ends, you will have a lot more usable lumber.
FredD
Already done *LINK*
Grant in Iowa
I end seal the logs as soon as I get to them or whenever they are bucked to length. I am using the newer Anchor Seal 2. It dries clear, which is probably why it is hard to tell it is there in the photo. I also use the stuff on green turning blanks.
I didn't get a couple of the logs cut to length before milling, so the butt end of the log is a bit uneven. They are coated, however.
I wouldn't dry lumber without it!
I have attached a link below...no affilliation, blah, blah, blah
Regards,
Grant in Iowa<--- enjoying the smell of the sawn lumber whenever I am downwind of the stack.
UC Coatings
