Shop vac filters
Shop vac filters
Shop vac filters
Doug Ridley
I have cartridge filters on both shop vacs and wonder if I should have paper bags over the cartridge filters. Will that cut down on the suction? Will it extend the time bwt blowing out the cartridge?
Re: Shop vac filters
Bill White
I use the accessory high efficiency filters on both of my vacs. No bags or extra stuff. Get the good filters and keep 'em clean. It ain't a bunch of fun, but neither is cleaning the shop toilet. Oh well.....
Bill
steve mackay
I spend $16 for a filter that lasts six months. Rap-rap on the side of the garbage can a couple times a week. In six months I'll go shell out anther $16. If the Shop Gods smile, they're on sale and I get two for twenty. Aditional bags, expensive filters, more accesories ? No thanks. My gig is complicated enough.
les winter
I use the HEPA filters and the drywall dust bags. I never clean the hepa and the bags work great for my router table and for sanding. Even routing MDF only leaves a faint discoloration on the filters. The bags aren't cheap, but my time is worth something.
Doug Ridley
Sounds like I better stick with my filters only.
Re: I like having the bags
Earl
Alan in Little Washington (NC)
Yes and yes.
If you want to extend the life of your shopvac filter, go much longer between cleanings, avoid reduced suction, then add a mini cyclone to the front end.
Big Dave
I use the standard filter with drywall bags. I haven't noticed any depletion of suction, and no dust escapes whan sanding or routing.
Two pennies worth...
Dave
