Have a question? Ask Woody!
Outdoor clear finish recommendation
Bill Tindall
Is there a non-yellowing clear finish that will survive conditions on a covered porch? The finish will be exposed to morning sun and occasional condensation and blowing rain.
I tried an aliphatic urethane from Target and it lasted less than a summer.
Re: Outdoor clear finish recommendation
Clint Searl
Clint Searl
How about an automotive clear coat?
Clint
Bill, I'd anticipate the real problem with anything will be expansion and contraction under the film. The water-white waterbornes cure up to a fairly hard film, although you might be able to add something to provide a little more "give" to the film.
I'd suggest that you call Jeff Weiss at Target 800-752-9922 here in NJ and ask him about your application. Target lists the Em2000wvx and Em9300 policarb as suitable for exterior use
Howard Acheson
The "non-yellowing" portion of your requirements is the issue. Any oil based finish will add some amount of amber color. What is it you are doing? Is the clear finish going to be applied over another finish? If so, what color is the other finish and what type of finish is it?
Oil based exterior or marine non-poly finishes last the longest in outdoor conditions
The only finishes that go on water clear are waterborne finishes. However, most of these are not as durable as oil based finishes. Few are intended for exterior application.
Second, all clear finishes that contain urethane or polyurethane will not stand up when exposed to the UV in sunlight. That is the reason your finish failed. Even exterior rated poly varnishes are short lived in sunlit applications.
Clint Searl
Clint Searl
My simple understanding is that the UV in sunlight will attack the wood under any clear finish over time, whether or not the finish contains UV inhibitors. If so, changes to the wood at the wood-finish boundary may destroy the bond with the finish. My inclination would be to go with a drying oil rather than a resin film finish.
Clint
tell me more
Bill Tindall
Can these materials be used on wood? Is a primer necessary?
Spar Varnish?
Ron Bauman
FredD
Spar Varnish , like McCloskeys Marine finish
FredD
Re: Outdoor clear finish -Log Home finish
Dave (PacNW)
Go with finish that is designed for use on Log Homes. These are the most UV resistant and longest lasting outdoor finishes you can buy.
Dave (PacNW)
that is what I have used
Bill Tindall
....the "polycarbonate-urethane product. I was told they used this stuff on boat trim. My experience was less satisfactory. First the mold attacked it and what the mold didn't turn black the sun turned white and it disintegrated....all in the space of 3 months.
Call Jeff
and tell him. He needs to know the conditions that caused his product to fail. BTW, Jeff Weiss is the owner of the company. Nice guy.
The issue is non-yellowing
Bill Tindall
I have a second table that is finished with ordinary spar varnish and it lasts for 5 years under the conditions on the porch before it needs re-coating. But, the spar varnish is over cedar and its amber color is not bothersome. This second table would not look attractive with an amber varnish on it. Of course it looks pretty crappy with black mold and flaking finish on it now so even spar varnish would be an improvement. .
