Re: Need Help with my DC
Alan in Little Washington (NC)
Thanks Hank!
I read and post here too!
Mark, I think you answered your own question- your clogged filters are hurting CFM, reducing the amount of dust collected at the machines AND reducing velocity in the cyclone which reduces dust separation efficiency, so even more dust and chips pass through to your filters- a lose-lose situation. A ClearVue with new filters has great separation and as long as you don't have any leaks* anywhere in the bin, around the lid seal, or hose from the cyclone, or you don't over-fill the bin, the filter(s) should stay clean for a long, long time. * those areas must be perfectly airtight!!
Don't add pre-separator- you don't need one with a ClearVue! Every inch of pipe or hose, every fitting, every bend, the cyclone, the filter- all add static pressure resistance to to system- the less the better.
The problem with overfilling the bin is more than a temporary one of plugging your filters and cleaning them. No matter what you do, you will NEVER get all the dust out of the filter. Some dust will always get permanently lodged in the tiniest of air passages in the filter media. Once too many of the air passes get permanently clogged you must get a new filter(s). You should investigate running your cyclone so it discharges outside instead of though a filter(s). Heat/cooling loss is a minor comfort disadvantage, but carbon monoxide from reverse flue gasses from a gas furnace or hot water heater is something else (is deadly!) and will prevent you from discharging outside.
Regardless of what you do, you should buy (commercial from Oneida or PSI) or build a bin high dust alarm. It has been mentioned I designed one that, if you can wire a table lamp, you can easily build one with parts from Lowes. At a minimum you can wire it to light, strobe, etc, or an audible alarm. If you are a little more electrical savvy, you can even wire it to shut off your DC. See my schematic at Hank's link.
I also have a new LED unit built from the ground up and aimed at the retail market. It has better and faster operation, wireless alarm, adjustable sensitivity, etc. but I have been working other projects, so haven't had a chance to make a fancy prototype to hawk around to the usual suspects. I have been using the first prototype of this new system for 6 months now and it works great.
Regardless, my original design still works well also, and is cheap- less than $20. I sent one to American Woodworker to test and write up, but I think they messed up the installation.
Here is one I built for a friend. I put it in a fancy package- the plastic PVC stuff was more expensive than the workings!
