We value your privacy.
We have a cedar shake roof about 17 years old, on a 12/12 pitch. I am considering putting some kind of a fire retardant on it. What products are out there & I'm not sure of even how to apply it? Maybe scafold & using a roller with a 22' handle???
I see you are north of the border (not the one with Mexico, the other one). Locally a 17 year old shake roof would be shot and at the end of its useful life, not worth trying to fire proof. You may have completely different results. In some places shakes last a very long time and you may have one of those, but its worth checking out.
Somewhere in the lower 48 there is a cedar shake and shingle bureau. Google them and look at their publications. There is an excellent Building Research Group on your side of the border as well and they may have publications on fireproofing a roof. I have some of their publications and if you can't find them, maybe I could rummage them up and get you the correct name as a starter.
I would think that if any such coating is available, you are going to have to spray it on to get anywhere near uniform coverage. May also be necessary to have a professional do it. I believe you are going to find there are no reliable field applied coatings for fire proofing. I believe there are some that are factory applied under pressure. If I am not mistaken they shortened the life of the shakes. The more I think about this, the more skeptical I become. Think Snake Oil.
Here is the State of California take on treated wood shingles with fire repellent.
For a long time wood shingles on housing was permitted up to the 1500 foot elev. line , then they changed it to required treated shingles, then few years later outlawed the wood shingles in areas where fire was a danger every season and finally said to hell with it and when I left . wood was pretty much a no-no.
In your particular case a 12/12 roof (45 degrees) it would take a unusual circumstance for you to get a roof fire.
If you have a clear zone of a hundred feet or better free of tress and tall weeds, I wouldn't sweat it, if your packed together in a subdivision , keep a eye on your neighbors activities , Barby or fireworks.
Subdivisions with 6000 sq. ft. lots or less can have a roof fire spread , roof to roof in dry season.
Last bit of advice , that steep roof is no place for you to try to work on.
If I were in the market for a shake shingle roof and they were still available, Redwood is the only commercially available wood that doesn't support fire.
That may be so, Fred. But here in your old home town, almost no one is still doing wooden roof coverings. The insurance companies have been having a field day, encouraging replacements by announcing that home owners had until the next anniversary date to replace with something else. Mine got redone 11 years ago for that reason.
And done in a rainy April, because it had to be done prior to the May 15 anniversary date on the policy...
Even the high dollar homes are something else, often cement based these days. Not too much metal in our county.
That is true Glenn and I mentioned the phase out of Shakes or other wooden shingles in my first post on the subject.
I haven't been out there work wise for a while and Redwood Shakes may be a thing of the past . but they are the only fire proof shingle and in the last part of the 19th century and well into the 20th, firewalls , particularly in commercial buildings where flammables and solvents were around all of the time , Redwood 2x4's , nailed flat side to flat side formed the first type of Firewall besides masonry in buildings and if you ever had to cut a window or door opening between shop bays , which I did twice and regretted the job both times because of the many nails encountered, you would wonder how long it took to erect one.
In the city itself when I first started working in housing in CA , we put up several town house type structures , after tearing down the old ones for lot space and under S.F. fire codes, each building had a one inch air space between it and it's neighbor and the adjacent walls were covered with Redwood Shiplap for firewalls, they may still do it that way.
That meant you were picking up a entire long side wall framed and covered with Shiplap by hand and it took every body handy to get it up.
