Need a Chuck Adapter
MarkK
I need to put a Jacobs chuck on a 5/8" shaft of a small variable speed motor that I have. Anyone know a good source? Part Number?
Thanks.
Mark
Re: Need a Chuck Adapter
I'll have to dig a little. If you can reduce the shaft to 1/2" I know you can get jacobs chucks with 1/2" thread. I'll look through my catalogs when I get back from the bike ride.
MarkK
Thanks, John but I found one just after I posted this.
This is Mark Kauder, BTW. Hope you are doing fine. I am not doing much woodturning, but have not given up all together.
Mark
Phil Joines
Most of the turning suppliers stock them. Probably Rockler too.
Msc's site is down for maint but there part number 56938152 is for 5/8" shaft to 1/2" x x 1 1/4" threaded shaft. They come with a nut and washers. I have user several for drill chucks, buffing & wire wheels. They also have the chucks to fit.
www.mscdirect.com
Re: Need a Chuck Adapter *LINK*
You probably already found the common adapter: various folks sell devices intended for buffing/grinding wheels that have a 5/8" female sleeve with two setscrews and a male 1/2"-20 thread onto which you could chuck any common chuck used for a portable electric drill motor.
I have found that these do not always center precisely - I think the manufacturers felt the need to build in enough slop to fit various motors - and they can sometimes "rattle" a bit around the center if you're using a drill bit or something else that's supposed to rotate exactly around the center point of the shaft.
It's been years since I got one of these, and it would not surprise me to find that they're now being sold with just one setscrew. If you're using one of these and have a choice, definitely get the kind with two setscrews, as they'll be more rigid.
Another solution might be the chuck designed for Shopsmith tools, which use a 5/8" spindle and a setscrew. Shopsmith attempted to solve (with moderate success) the concentricity/rattling problem by machining a tapered flat on the spindle that grew deeper away from the end of the spindle. This caused the setscrew to pull the accessory being attached firmly against the end of the spindle, and kept it tighter in operation. I've yet to see a motor shaft like this - you would have to file the flat on your motor. I've got an older iteration of one of these spindles, and it's pretty good quality; I don't know what the current ones are like.
Shopsmith chuck
MarkK
In this case, a need it for my other hobby - shooting/reloading. I need to hold some bits that turn at relatively low RPM.
http://www.hobbytool.com/browseproducts/5-8--Chuck---Arbor.html
Mark K.
Yes
that's the adapter I tried to describe in my first suggestion.
MarkK
Thanks to all.
Mark
