Rechargable battery storage recommendations
Bill Tindall
This information comes from a friend that is a battery expert as evidenced by the fact he works for a company that makes some types of rechargable batteries and he has written books on the topic.
The case for Lithium Ion batteries is straightforward. They should be stored in a partially charged state. When fully charged, as well as fully discharged, there are internal chemical reactions that slowly destroy the battery. A quality charger will limit the charge during recharging to optimize battery life.
The situation for Nickel Cadmium(Ni-Cd) and Metal Hydride (M-H) batteries is more complicated. The following are factors affecting the situation. Starting at a fully charged state they will "self discharge" sitting on the shelf at a rate of 1-2% per day, ie they will "go dead" in a few months. When fully discharged there are internal reactions that slowly destroy the battery. However, if charged from a less than fully discharged state the Ni-Cd battery will loose its capacity to reach a fully charged state. This problem is less so for the M-H battery. Further complicating the situation the component and design features of these battery types, as well as the charger, have a large effect on battery life. The best chargers discharge and then recharge the batteries so as to maintain capacity and prolong life. There are documented cases of pacemaker Ni-Cd batteries lasting for 30 years with optimum recharging procedures. (My drill batteries didn't last this long.)
So, what to recommend? Definitely do not store these batteries fully discharged, nor should they be stored for long periods of time without out recharging. However, if the charger is not sophisticated, then charging before the battery is fully discharged will shorten the effective life of the battery. Ideally, buy a quality battery and charger and charge periodically before the battery becomes fully discharged.
