Drying wood questions
I am making a cutting board out of end grain blocks of Osage Orange. I am "rescueing" the Osage from the burn pile or actually the trash heap. I ahve cut a buinch of blocks that are all two inches thick and the range form 3 x 3" down to 1 X 1". Some are angled and nt square at all. Right now the blocks are sitting in loose formation on a scrap of plywood in my green house, drying. They came out of a short log that was two or three years old.
I was wondering if anyone has any idea how long to let them dry? I was thinking of weighing several of the block occasioanlly and seeing if they are loosing weight? Any thoughts?
Also, I weighed the entire board and at the moment it weighs 19 pounds. That includes the plywood, but still it must weigh 18.5 pounds. Two inches is rather thick, but what do you think should be the minimum? The board will be about 13" X 18"I'm thinking thinner will be lighter, but I don't want to get down to "fragile". It is end grain.
Re: Drying wood questions
You've got choices.
You can weigh the pieces over a period of time. When you reach an equilibrium weight where you have little or no weight change - they are at a "rough" equilibrium moisture content.
You can dry at the 1 year per inch of thickness standard. Not really applicable to your small pieces. For the small chunks that I use for blocking pieces and to add onto the sides of arms, I usually let them dry for a couple of days at 120 F. I figure that your greenhouse is probably a good 90 F. So figure a week or so - depending on how wet your greenhouse is.
Moisture meters work well.
Cheek method can work for some. Hold a piece against your cheek. If it feels "damp" - then it is. When it feels warm and dry - it usually has reached EMC. I don't "trust" this method - but it sort of works.
My green house is actually set up to produce heat for the house in the winter. Its attached and in winter I can syphon heat out of it into the house. For the last couple of years it has served as a kiln of sorts. It's full of wood that I have dried. Right now, Its open and aired out to not build up heat.
Wonder if I could put these pieces in the oven for a while? Just afraid that would destroy them.
Barry Not having any idea what the original MC of the wood is can't even begin to tell you how long it takes to dry. Weighing is the best method I know since I don't have moisture meter. Do a test piece. Put one piece in the oven and weight it before and after. Try a moderate heat like 120 -150. If you get checks it's definitely too wet to dry this way. If not let it sit longer and weigh. As always when it stops losing weight it's dry. I would heat it in cycles at first. I find the wood will loose more weight as it's cooling down. In my experience here in Tennessee if you dry wood this way you have to let it sit for a day or say to pick up moisture other wise it moves after you glue it up.
Bill Tindall
I like a board 1 1/4 to 1 1/2" thick. Thicker and it gets very heavy.
Dry until the blacks cease loosing weight. I suspect 2-3 weeks will do the trick. Humidity in a green house may be high and retard drying.... a good idea early on. You may want to finish them off in an attic or loft.
Re: End grain cutting boards
Howard Acheson
There is a little engineering that needs to be considered when building an end grain butcher block or cutting board. First, choose wood where the growth rings (viewed from the end) run as close to 90 degrees or parallel to one edge. Remember, the expansion/contraction is about double along the annular rings verses perpendicular to the rings. You've got to keep the grain running in the same direction as you glue up your strips. In other words, don't glue a flatsawn edge to a quartersawn edge.
Next, the way butcher blocks are made is to glue up strips of wood like you were making a laminated type cutting board. These laminated panels are then run through a planer to flatten them and bring them to equal thickness. Then the panel is crosscut into strips of blocks equal to the thickness that you want the butcher block to be. These block strips are then glued together again keeping the grain running in the same directions.
Not paying attention to the grain orientation will lead to the block cracking and/or joints being pulled apart.
A type II adhesive will work just fine however, you need to be sure you do everything right to get good adhesion. Your glue faces should be flat and freshly cut. It they were cut more than a few days earlier, freshen them up with about three swipes with 320 sandpaper and block to keep the faces flat.
Generally, threaded rod is not used as maple has quite a bit of movement when it's moisture content changes. Threaded rod would restrict this movement and either deform the block or pull the nut/washers into the wood when it expanded leaving the rod performing no function when the wood later shrinks. Proper gluing will keep the block together.
