We value your privacy.
When I paint with oil based enamel I pour it into a small painting pail. The ones I get from HD are just the right size but the edge has a bit of a "roll" on it and it causes the paint to drip.
One, your brush (or roller) will pick up contaminants that you will rinse back off into the paint can the next time you dip.
Two, leaving the can open allows the solvents in the paint to evaporate, changing the consistency, workability and performance of the paint. Paint will dry on the sides of the can, and fall in, putting chunks in the paint as well.
Always pour into another container from which you can brush or roll, and only put in there what you'll use in a short time, depending on the paint.
All the arguments that are advanced to suggest painting from the can is not a good idea also apply to what ever one transfers the paint to. Solvent based products are formulated too thick (to meet EPA requirements) so they invariably need to be thinned anyway, so solvent loss is not a factor. BTW, Flexner has an article in the current Woodshop News on thinning everything for best results.
If you intend to save remaining paint for more than a few days, it indeed is not good practice to paint from the can. Paint cures by reaction with oxygen. If you paint from the can the paint curing reactions will be initiated during the time the can is open and continue after it is reclosed. The result will be a skin of cured paint over the remaining paint and eventually a thickening of the entire remaining paint, rendering it useless.
It is best to reserve remaining paint by transferring it to an air-tight container that the paint will largely fill with little oxygen-containing head space. Next best is to withdraw the paint that will be used and promptly reseal the can. Store it upside down and shake it now and then for the first few days to distribute oxygen throughout the liquid. I am presuming that if one is storing "used" paint you are too cheap to buy the expensive oxygen displacement products. These work but they are not economically justified in my shop. Don't use propane in a less than a half filled can. I have previously posted the results of this flawed idea (it seemed ingeneous at the time).
As far as what to transfer paint-in-progress to, the answer is anything clean that the brush fits in. I save cans for shop usage- tomato paste to institution tomato cans. If you have paint running down the outside of the container your brush tipping-off technique needs modification. I just touch the brush to the side of the container after loading. Small buckets are ideal but I'm too cheap to buy them.
If you are not going to save remaining paint for more than a few days just paint from the can.
Flexners article address'es the difficulty many have in applying finish without brush marks or spraying without getting Orange peel.
His fix for these problems is thinning the finish for better leveling properties and a flatter look to the finish.
He specifically names all of the traditional and modern finishes for wood ,except paint.
Thinning paint by a contractor in CA will immediately get him removed from the job and his contract voided and he will be subject to back charges to fix his fly by night approach to painting.
Paint is best applied and insisted on in grades and standards publications of municipalities to be applied as directed by the manufacturer.
Bob's article is well worth reading if you ever wondered about the various wood finish's and how well they work to protect the wood.
Here is his summary:
"Thicker finish films are more effective for protecting wood from water penetration and moisture-vapor exchange.
Thinned coats of finish flow out and level better better than unthinned coats."
It is my personal view that finish film appearance depends at least as much on technique, quality of applicator and understanding what your doing as fiddling with finish viscosity and vehicle manipulation like your genetic code included a Coating Chemist's background.
