We value your privacy.
Finishing a room in a basement with drywall. The room has no windows. It does have a door that leads to the rest of the (finished) basement. Any hints on controlling the dust so that it stays in the room and the sanding person can see etc?
LOL ! I'm doing the hallway ceiling right now. Close all the doors and doing it by hand SLOWLY. No rush. Lots of breaks for the dust to settle. Couple of years ago I bought a sander with that nifty look'n dust skirt to hook up to the shop vac. Boy was THAT a waste of money ! Nuth'n to do but to do it ! Hang in there.
Unfortunately they are all somewhat noisy. If you are doing it by hand, you can get a sanding platen that has perforations and uses the sanding screens. You hook this up to a shop vac with HEPA filter or a shop vac with one of the "water bucket attachments". If you are sanding with a mechanical sander, you hook your shop vac up to the sander with the aforementioned filter.
You can also use a drywall mud that is "lower dust" - I think it was the Sheetrock Plus 3 compound.
If you do use the "water bucket" - make sure not to trip over the bucket/hoses (DAMHIKT).
If you work very hard at getting a very, very thin coat for everything after your initial coat and then do a skim coat over the entire surface, you don't have to sand. We've done this in a couple of rooms, and you get a surface that looks like the old plaster walls (at least as done by the plasterers who worked on our 1895 house).
If you ask the pros what is the biggest mistake amateurs make they will say "they build up too much plaster on the joint". It's amazing how little sanding the pros do.
Unfortunately, as a painter, I have gone behind way too many "professional" drywallers who did NOT use too much mud, but sanded too much anyway. As a result, the paper around all the joints and screws is rough as a cob and cost me some extra time in sanding after primer.
I just helped a colleague on a church gym/classroom addition where the drywaller was a member of the church, did a lousy job, and then the church wanted semi-gloss paint on everything--with harsh lighting to boot. Yikes. We did the best we could without losing our shirts. The kicker is that the drywaller told the pastor and the builder that the primer we used caused the paper to swell. Riiiiight.
The method I used was just to tape filters over any return ducts, put on a face mask and sand being careful not to sand through to the paper. If you patch those areas, they show badly as mentioned above. When I'm done I take the shop vac with a brush and go over everything. I tried sanding with the shop vac but just didn't have an effective way to do that.
The dry wall guys that work for out University just use damp sponges without sandpaper. I don't know if it's a special mud, sponge or both they use or what but obviously doesn't leave any dust at all.
The last time I took on drywall I used water for 'sanding' in two ways.
One was to use one of the water bucket filters in the link.
The other was to use damp sponges to smooth out the high spots. It took some experimenting with sponges to get the right one and how much water to have in the sponge. If I remember right I got the sponge at Home Depot with the drywall supplies.
After using these two tools I had very little to clean up. I used drop cloths to keep the floor clean so there was really NO mess aftewards. The buckets of water went out in the yard.
John is right. If you practice doing the taping well, you can eliminate most if not all the sanding. Get a big coarse sponge and wipe down the joints.
To Me, the "trick" is to put less mud than you think you need. Very thin layers and build slowly. I like the mesh tape for the flats. put it on first, its sticky. Bed a very thin layer of mud over it. Do the smoothest job you can. Assume you will have to add more, not put on a bunch and sand it into submission. Pro's can get by nicely with three layers of mud. Us amateurs should think five. Actually, it three with two touch ups. Each layer is faster than the previous.
The sponge works well for "killing" the edges of the joints. Almost no matter how hard you try there will be a very thin edge to the seem where the mud meets the drywall. You can wipe that off with a sponge faster than you can sand.
Also, use 80 or 100 grit sanding screens. Not finer. If you sand the surface with too fine a paper, they will shine. DO NOT sand the paper of the tape enough to rough up the surface.
Also, get good quality knives. You will need a 4 and a 6 and a 10" one.
...unfortunately, I've met far too many carpenters who had far too much confidence in my skills and abilities without ever having seen my work, if you know what I mean.
And, if I see a carpenter with a caulk gun, I will take it from him. I haven't met one yet that was even reasonably competent with one.
I used the gizmo that attaches to my "shop-vac" (actually a PC vac) with different screens to sand the big stuff, then a large damp sponge to even stuff out. My dry-wall technique is horrible, but this worked fine. As others have said, many thin coats work better than one thick coat - at least in my limited experience.
I've done my own work on this house, and have made the mistake of sanding through to the paper - and then paid the price when I went to paint.
The technique I'm suggesting, since it doesn't involve sanding, avoids the problem. It is NOT easy - my shoulders ached when we were putting those thin coats on. It turns out to be a lot of work to spread it that thin.
If you use the drying type mud (comes pre-mixed in a bucket) rather than the setting type (powder in a bag you mix yourself), then you can get away with very little sanding. As others have suggested, do a good job by not putting on too much mud in the first place, then when dry, knock down the high spots with a trowel or paint scraper, then do your smoothing with a wet sponge. You can get 90% of the way there with this method, then you only need to do a light sanding at the end. Get one of those sanding blocks that connects to a shop vac hose. That should keep most of the dust out of the air.
