Calculating Angles
Calculating Angles
Calculating Angles
Ed
I have an amateur question about how to calculate angles. I am attempting to build a Gazebo type Bird Feeder with a four side, Pyramid style roof and I can't for the life of me figure out how to calculate the joining roof panel angles. I have figured out that as the pitch changes, so does the angle. There has to be a formula, calculation or something that enables you to accurately calculate the proper angle based on the desired pitch, I just can't seem to figure it out. Can someone please tell me how this is done?
Re: Calculating Angles
Try this *LINK*
Lee Schierer McKean, PA
Here's a link to a compound angle calculator. It should give you what you need.
Lee
Compound Angle Calculator
Re: Calculating Angles *LINK*
John McGaw
If you have an older version of Windows, XP for example, this program will give you what you want. I wrote it a while back but quite stupidly I have lost the original source code and haven't had the ambition to re-invent this particular wheel to work with newer versions of the operating system. (actually the program itself works on versions up through Windows 7 but the installer balks)
http://johnmcgaw.com/other3.html
mdclor
Could you draw it full sized and then use a protractor or a sliding bevel to measure the angles directly?
FWIW,
Merle
FredD
Two ways to go , read up on Pythagorean theory , or tell me the pitch and I will tell you the angle in degrees..;-))
I have in the past made large feeders and some actual dove houses using a six sided , rather then a four sided approach, looks better.
FredD
Ed
WOW...Thank you everyone! I don't feel so bad now, I was expecting someone to tell me to just add ten, or something simple like that. This is actually pretty complicated! I never would have figured it out without the help and the terrific links! I can't thank everyone enough...consider your hands shook!
