Tree Stumps
Tree Stumps
Tree Stumps
George
I am looking to make seats from tree stumps and would like to know the best way to prepare and finish the stumps. Thanks
Re: Tree Stumps
Re: Tree Stumps
First task is to distract the gnomes long enough to let you dig out the stump. I find that a few bowls of Luck Charmes sprinkled with a few iron pyrite crystals will keep them occupied, but when the sugar rush crashes, they'll be back with a vengeance.
So, once you've got the stump out, you'll want to power wash at least the upper portion to get the rocks and stuff out.
Once clean, cross-cut baloney slices of 3 to 4" thickness. Stack and sticker them with a lot of weight on top (concrete blocks are good) to hold them as flat as possible, and tarp over the stack to retard the drying. Slower is better here.
It will, however, be extremely lucky, depending on the species, if you avoid radial cracks from the pith. These can be stabilized with butterfly inlays when dry.
Lastly, haul away the rest of the rootball before the gnomes find out what you've done. They get fairly pissed at people who take their furniture, and have been known to hire Lorax types who also open carry heat.
Re: Tree Stumps
Couple thoughts on this...
If you want to use the whole stump, be aware that the water/moisture in the stump will continue to drain through the bottom of your "chair" for a long time, rotting anything under it. This is why I have only used stumps for seats around our fire ring in the woods. If you want to make a real piece of furniture out of a stump, I suggest getting a large enough stump that you can cut the chair blank out without getting the pith in it. That way, as it shrinks, it won't develop those familiar radial splits.
You can shape the stump with chainsaws and Arbortech type carving disks and finish up with any kind of grinding/sanding gear you might have. Do be careful about the water/moisture issue, though. Some kind of barrier is in order unless the wood is actually quite dry, and even then I would recommend some kind of feet to stand it off your floors and carpets.
