Larch for outdoor projects?
Simon St.Laurent - Dryden, NY
I've been looking locally for cedar or something like cedar for some outdoor projects - a barbecue cart, trellises, and maybe a table. I don't love working with cedar because it seems to get splintery over time outdoors, and likely because the stuff I've used hasn't been ideal.
I've had a few people recommend locust for permanent outdoor projects that don't have to move far - HEAVY - but I've also heard of people mixing locust and larch, which I guess is also called Tamarack.
I have a line on some larch, and the guy gave me a sample to play with. I've seen some nice work done with it.
My question for you all is whether it'll hold up in the hot/cold wet/dry sunshiny outdoors? I've found mixed answers in the books I've checked and the conversations I've had. This will probably mix them up some more...
Re: Larch for outdoor projects?
I don't have an authoritative source and I am certainly not one myself, but my understanding is that there are a number of "top tier" woods for durability, locust is one as well as redwood, heart pine and a couple of more. Western red cedar is less durable than Redwood. So is Eastern red Cedar. Fir is in the second tier and I believe larch is similar to fir but perhaps slightly less durable.
There are many variables. Old growth Redwood is far more durable than second growth. Heart wood is far more durable than sap wood. These two things are true of many woods. I can't remember which locust is the more durable, black or yellow.
Also the use and location matters. Wood sitting with end grain touching the soil or buried as a post will rot much faster than wood in the air. Wood that is somewhat protected, say by a roof, will last much longer than wood that is fully in the weather.
So, You could use locust for the parts of you project that will touch the ground and larch for the rest. The locust may still outlast the larch.
Ron Jackson
I have seen 100 year old barns with the original Tamarack shingles still intact. The only negative would be it's tendency to split. That being said Black Locust is very durable. I have seen it used for rub rails on boats, batter boards on dump trucks, trailer beds, decks, you name it.Tough stuff !
mdclor
Simon,
As stated black locust will last for a long time, perhaps as long as 40 years in the ground. However, it is verrrry hard and not easy to work. Have you considered white oak? It will also last a long time even if the board ends are in contact with the ground. In your area it shouldn't be too expensive. I have no knowledge about larch or tamarack.
FWIW,
Merle
Sgian Dubh
Most of the larches are described as moderately durable. This means an expected life of 10- 15 years in ground contact. Larch gets this durability from the fairly high resin content and other factors. Here in Europe, for instance, larch is used a great deal for residential fencing material, eg, larch lap fencing, posts, etc. Slainte.
It's fine for outdoor projects. Very durable.
Ellis Walentine, Host
Thanks, and the general idea
is that I'd like to use larch for things which are entirely above ground, and locust anywhere I need to put a post into the ground.
So the BBQ cart, which needs to move, would be all larch, except perhaps where the feet touch the ground. (The other side will have wheels). The chicken coop would be built with locust posts, and then larch attached to that above ground level. Trellises would probably be all larch, with metal or locust posts holding them a little above the dirt.
It sounds like all of this is reasonable, at least as reasonable as it gets. Definitely let me know if you think otherwise!
(I'd prefer to keep the white oak for indoors work.)
Reasonable enough
I'd suggest putting a protective finish on the wood regardless of what species you use.
Jesper, Denmark
Re: Very reasonable....
Jesper, Denmark
Larch is a common boat building lumber around here, used for the planking on oak frames. It will weather just fine above ground with no additional protection. It is also a common wood for pilings used for nets or dock construction - again with no protection.
Black Locust will outlast three post holes, so fine for the in-ground use with no other protection.
If the cart has to be real woody, turned locust wheels would also work.
With locust, remember to pre-drill screw holes and lube the screws with linseed oil - or you will have a lot of broken screws and you will never get them out again later.
