OT-computer question
Doug Ridley
Somehow the RUN and SEARCH have dissapeared from my start menu. How do I retreive them?
Re: OT-computer question
Go to Search and type in RUN.....Oh, Wait...Never-mind, I have no idea....
Sorry, couldn't help it... :)
del schisler
try this Do a right mouse click on your start button Down to properties Than to customize click on that go to advance than scroll down and make sure that Their is a check mark in the search comand and run comand That should do it good luck
Doug Ridley
Del, I have done that and it doesn't work. They are already checked. I have unchecked them and rebooted then checked them and rebooted and still no luck. Any other suggestions?
Bill Howatt
Try this (they are near the vey bottom of the list):
1. Right-Click the Start menu.
2. Select the "Properties" menu option.
3. Click the "Customize" button.
4. Click the "Advanced" tab
5. Scroll down the list until you see "Run Command" and "Search". Put a checkmark on these two items.
6. Click OK
Doug Ridley
That does not work. Both are checked and have been unchecked and rechecked several times. Something else has to be done but I have no idea what it is.
Grant Wilkinson
What operating system are you running?
Doug Ridley
Windows XP
Grant Wilkinson
Doug: I should have also asked if you are using the "classic start menu" or the "start menu".
Doug Ridley
Start menu, not classic start menu
Doug Ridley
Leaving for church now. Maybe someone will come up with an answer by the time I get back. Thanks for all suggestions.
Doug
Doug Ridley
I'll do that this afternoon but look-- I just switched to classic start menu and they are both on there. How do I get them on the regular star menu. Back after church.
Doug Ridley
Grant, I looked at that and I'm afraid that's over my head. I'll save it though 'til someone is here who can do it. Thanks,
Doug
