OT - Diesel in a gasoline container
Terry Alexander
Someone (not me....and "she" might read this) filled up a 5 gallon plastic gasoline container with diesel. I have a diesel tractor, so no problem using what was put in there. What I don't know is.....
Can I rinse the container out with gasoline and then use it again as a gasoline container or is this now and forever a diesel container?
As always.....thanks in advance for your valued opinions/advice.
Terry Alexander in West Texas
Re: OT - Diesel in a gasoline container
Charles in Mtl.
my opinion is there will be no problem to reuse it a gasoline container. Just drain out all of the diesel and it should be fine.
Make sure you get a good winse
Forrest Addy
A little gas in diesel no prob.
Diesel in aa caas can? Make sure you get a good winse. As little as a teaspoon of diesel per gallon of gas will make a gas engine knock like crazy.
Dale Lenz
Back in the 60's
Dale Lenz
there was a rumor about putting 10% diesal(sp) with your gasoline car engine to clean your motor out. Tried it a few times, did it help the motor, don't know, did not seem to hurt it any. Recall, that was a carburatered(sp) engine. I'd think you'd be fine. Spelling is terrible today, : ' >.
Re: Kerosun stove sidenote warning
Bill Turpin in WNC mountains
A teaspoon of gas put in a gallon of kerosene will lower the flashpoint below room temperature. Therefore the stove blows up in your living room. Nnever use a gas can for kerosene during the winter!
You're good ! . . .
steve mackay
Back in the bad-ol-days when my ARMY was switching from mo-gas to JP-8 it happened all the time. Won't hurt anything to swish a bit of gas around and empty but I wouldn't worry about it.
Jason Roehl in Lafayette, IN
Shouldn't...
Diesel and kerosene are practically the same thing, and most of the fuel treatment products you can buy on store shelves are mostly kerosene. That, combined with all the sensors, computers and on-the-fly tuning on modern engines, you can actually put quite a bit of other hydrocarbon-based chemicals in your gas with nary a problem. In fact, I've heard that diesel and kerosene are quite effective at cleaning fuel injectors at up to about 10% concentration. Knocking is pre-ignition due to timing or high cylinder temperatures. Diesel actually will help keep the cylinder temps down in a gas engine since it doesn't burn as hot as gasoline in a naturally-aspirated engine (a turbocharged/supercharged engine might be another story).
Jason
Diesel as an engine cleaner
John Muir, of "How to Repair Your VW for the Compleat Idiot" fame, recommended running a cup of diesel through the motor by pouring it into the carburetor while holding the throttle fully open. I never tried it; our bus motors never lasted long enough to worry about cleaning the motor.
Won't it effectively lean the mix?
John in NM
Like adding too much oil to a 2-cycle mix... a gasoline engine may not develop enough compression to burn the diesel, so then the only effect aside from a bit of cleaning would be a leaner mix, assuming the computer didn't somehow know to reduce the airflow.
Re: Won't it effectively lean the mix?
While diesel engines have up to about twice the compression of a gasoline engine, that's what it takes to burn 100% diesel. We're talking about a small percentage of diesel that would be fully dissolved into gasoline. The burn temperature of gasoline is higher than the ignition temperature of diesel, so it's all just gonna burn (remember that gasoline engines will burn oil that gets by piston rings or the valve guides, and oil has an even higher ignition temperature than diesel). With computer control, and the fact that diesel contains more energy per volume than gasoline, I suspect that the computer would decrease the fuel to air ratio, thereby leaning out the mix, but I don't think it would be in any way damaging. Any large increase in temperature would be taken care of by temperature sensors telling the computer to enrich the mixture, cooling the cylinders. In older EFI vehicles, too much diesel in the gas would push the fuel/air mixture outside the adaptive limits of the programming, but vehicles less than about 14 years (OBD-II) tend to have pretty wide control of the fuel/air mixture.
Jason
Look at the smoke...
John in NM
In my experience, oil in the fuel does not burn even close to completely and has a detrimental effect on the air/fuel mixture.
Two examples, an auto burning some engine oil (I've had several of those! :D), and a 2-cycle like a chainsaw. Exhaust is very smoky, much more so than even the worst diesel, and the smoke is blue rather than black - the oil is hardly burning at all, and that's at a fairly low percentage in the fuel.
Your explanation sounds good, but it is contrary to experience, so I'm at a loss to know where the discrepancy lies.
I agree.
Basil
A few drops of one in the other ain't going to hurt anything....as long as it's going in the tractor, car, lawn mower, etc. and not in a heater or something in the house/shop.
You guys may be mssing a point.
Forrest Addy
You guys may be mssing a point. A little diesel in the gas Vs a little gas in the diesel makes lttle difference in the heating value of the mix as a fuel. How it behave in the engine is another matter.
Diesel as an engine fuel is rated in terme of "cetane" which has to do with the fuel's abiltiy to spontaneouly combust when injected in hot compressed air. Diesel is injected at the instant before the power stroke.
Gasoline is rated in term of "Octane" a measure of a fuel's aabilty to NOT spontaneouly combust in hot compressed air; ie knock. A gas engine compresses a stoichiometric fuel/air mixture then ignites it with a spark to produce a power stroke. High cetane rating is good in a diesel but bad in a gas engine. High ctane is good in a gas engine etc. Octane and cetain raings are antithetical.
Diesel in gasoline destined to be a gas engine fuel is bad. It wll make it knock.
BTW that old shade tree yarn of addng a little diesel to gas to "clean" a gas engine? Might have worked in the 1920's on make and break engines and that's with 4 to 1 compression burning high ash gasoline of 60 octane o kerosene. But don't try it in modern engines. The constant knocking may cause damage and the "cleaning" it does is nil. Modern fuel are already clean and today's 200.000 mile engine on today's pump gas is typically cleaner than a 20,000 mile engine of the 60's.
You have to re-qualify good ol' boy stories for time to time. 99% of the time the technology renders them moot. Or they are mere BS some old guy told you when you were young and impressionable. My personal favorite along those lines is "A bear won't attack a virgin."
FredD
According to Holt Motor company in Abilene who does all of my vehicle maintenance, Mike Holt was explaining to me the difference in Compression of Gas and Diesel rigs .
For my Diesel PU , he said " if you converted the compression ratios of Gas and Diesel to PSI , the V-8 Diesel engine would be in the 2000 to 2200 PSI range while the V-8 Gas engine was like 120 PSI" .
FredD
My relationship with bears...
Tom Dunlap
Maybe that's why I'm still on such good terms with bears.
Your numbers are way off...
The 120 PSI isn't too bad. But a typical on-road diesel will have a compression ratio in the 16:1 to 22:1 range. Now, if a gas engine with a 9:1 compression ratio develops about 120 PSI, then something with an 18:1 compression ratio will have an internal pressure of about 240 PSI. It has to do with the good ol' gas law--P(1)V(1) = P(2)V(2). Halve the volume, and you double the pressure.
So, it's about double the pressure of a gas engine, not 20x. Now if you want to talk about direct-injection common-rail fuel pressures in a diesel, then you're talking about 35,000 PSI...
Jason
Re: Look at the smoke... *LINK*
It's blue because it's mostly combusted. Try burning some used motor oil sometime--the smoke that comes off it is black because that's soot, or unburnt oil. Oil does burn in a cylinder, though probably incompletely. That's why piston rings are important--they wipe most of the oil off the cylinder wall while being a barrier between the flame front and the oil.
Here's a few charts for you:
http://www.tcforensic.com.au/docs/article10.html
Look at table 2.2. You'll see that the ignition temperature of gasoline is 257�C and that of motor oil is 260�-371�C. Keep in mind that's just the minimum ignition temperature--the spark will be much higher, as will the flame front in the combustion chamber (471�-560�C, from the bottom of Table 2.2 in the link). So oil or diesel mixed in gasoline will burn, it's just a question of how completely, and what the effect will be.
Jason
I don't see how it would knock...
Diesel engines need a compression ratio exceeding 16:1 or so, whereas the typical gas engine is about 8 or 9:1. Knocking is pre-ignition, and the lower compression shouldn't cause that to happen with a small percentage of diesel in gasoline. Gasoline is MORE susceptible to compression-ignition than diesel. It happens quite a bit in rebuilt engines where the cylinder heads have been resurfaced (removing some height), effectively raising the compression ratio, and knocking/pinging/pre-ignition results.
Diesel fuel's benefit is that it is resistant to compression ignition, allowing for/necessitating much higher compression ratios, which is much more efficient.
Jason
Re: Your numbers are way off...
FredD
As it turns out Mike was quoting injection pressures and on my 6.6 Turbo Charged DuraMax Chevey PU , that is in the range of 23,000 to 29,000 PSI depending on the year of the motor.
In addition to confuse the picture even more , immediate after I took delivery of the truck , I had Holt install a after market chip which meters the fuel far better then the factory version and depending on the level you have punched in , will increase the HP as much as 165.
I have never tried it on 5 yet, Mike advised having the truck pointed the direction you wished to take before hitting the gas as it were ;-))
On 3 where I keep it , it has 21.8 for mileage which a 99 Ford I had running a International Diesel never got over 17 , this may sound trivial , unless you have a 1984 3/4 ton 462 C.I. Ford sitting in the barn which never got over 10 MPG with a tailwind.
FredD
