Mastech multimeters
Mastech multimeters
Mastech multimeters
Charles in Mtl.
Does anyone know what these are like? I would go for a fluke except they are much more expensive.
Re: Mastech multimeters
Randy Johnson
What are you using it for?
For simply checking for continuity or �close enough� voltage readings a cheapo from the local borg will do the job. I am partial to analog meters and that�s what most of the cheap ones are. Both of the two digital meters I�ve bought (One multimeter, one volt/amp meter. Both were moderately expensive) are now worthless because the LCD display is no longer readable.
Charles in Mtl.
Randy,
My needs are just general voltage checks etc.....nothing requiring a great degree of precision. You are right.....the el cheapo model will meet my needs.
Bill Howatt
Cdn Tire often has multimeters on sale for very good prices.
The cheapos that are being sold now would have cost a few hundred dollars in the past.
Bill
Paul Cates - Henderson, KY
I had a Mastech MS8268. Used it maybe a half a dozen times...sometimes it was accurate, but other times it would show a reading that was obviously wrong. By the time I figured that out, the 1 year warranty expired. Tossed it in the recycle box and purchased a Sperry (5 year warranty) from the local Menard's. Lesson learned. If you just need basic readings, buy a $5 or 10 cheapo.
