We value your privacy.
I'm moving to a new house with a three car garage. We specifically got the three car garage so I can make my shop there. Now I have to figure out a way to divide the garage to separate my shop.
I don't want to build a stud wall. I'm thinking about just building a lot of cabinets that reach from floor to ceiling. One co-worker suggested an accordion wall that I could pull back or maybe make the tall cabinets on rollers so they could be moved out of the way.
I'm looking for more suggestions. Any help appreciated.
I thought you were looking to build one, and I was going to suggest you build it in my backyard, where we have lots of space...
I like the cabinet idea. Any shop needs lots of storage. If you're a power tool guy, an accordion wall won't do much to keep the dust out of the non-shop part.
I personally like the idea of tall mobile cabinets, but I would also add a curtain, set up similar to the ones hospitals use to separate the semi-private rooms, to help keep the dust out of the rest of the garage. JMHO
Regardless of what you do, down the road you will wish you had gone with Bart�s suggestion. There is no such thing as too much space.
You may not want to build a wall, but that is what I would do. Anything less and it will be a constant battle moving the makeshift wall back and forth as each of the two sides need just a few inches more for something. In addition, as has already been noted, unless you have an awesome dust collection system that you use 100% of the time, everything on the non-shop side will be coated in dust.
Choice two would be making the entire wall cabinets.
Roy, just to chip in, if you build a row of high cabinets, they will become immovable once they are full of stuff, so in effect become a wall. So why not build a stud wall divide and as many have all ready mentioned, keep each part separate and the car garage free of dust. Your wife will probably be happy at that too.
I didn't want to share the garage with cars, bicycles, lawn mowers, etc., etc. so I designed the attic with a sturdier floor and different roof line for more headroom- that is where I put my shop. I added a loft door at one end and outfitted it with an I-beam hoist to raise and lower machines, materials and projects. I designed the hoist so it stows neatly out of the way inside the shop.
My shop is in the garage (2 car garage). For about 1/4 of it, I did something similar to the hospital curtain idea, but I used plastic dropcloths. I screwed 2x2s to the ceiling in an "L" shape and stapled the plastic sheeting to it. At the floor level, I laid down a couple of 2x2s and cut the plastic long enough that I could roll the 2x2s a couple of times (rolling in the edge of the drop cloth) then staple that. The 2x2s weighed down the drop cloths. I put this rig up in 2007.
The only really "dirty" machines I have are a Craftsman contractor style table saw and a 13" Rigid planer.
As has been noted in other posts, it contains the chips, but dust goes EVERYWHERE in the garage.
Also, the plastic at floor level got kicked around, etc, and the 2x2s are no more. The plastic is still hanging there, and I put a bunch of spring clamps on it to weigh it down. When the door is open on a windy day, the plastic lofts like sails. It never did all I intended, but I've left it in place because it does contain some of the debris.
I've thought of putting up a rigid wall, using just 2x2s and masonite or something similar, to consume less of the floor space and maybe cost a little less, but I've gotta work around the roll up garage door. So, it is what it is.
The only real lesson in here is that dust will migrate around anything that's not sealed up.
A friend of mine asked me about 6 months ago if I wanted his old legal file cabinets - the steel cabinets with garage door fronts, and rollout drawers.
I used them in my shop for tool storage - WONDERFUL.
If you can get hold of something like this, gho fur it!
Otherwise, build that stud and drywall wall - sound insulation, dust separation, etc, and use it to mount cabinets with garage door fronts on them (the rollout drawers are less useful above chest height - best down low)
I would make them with framed plexi-panel doors on the front for identification of contents. It's always better not to have to blow off the dust for tools before you use them.
I agree with some of the others, put in a wall. You can put a 48" wide double door, or slider in it for access to the other side. A solid wall will also give you "hanging" space on the other side. Moving tall cabinets, in my opinion, as a disaster waiting to happen, serious injuries have happend in the past and will continue to happen. Tall cabinets should be attached to a wall. In a commercial setting OSHA requires it, so would any insurance safety engineer.
I plan to keep two cars in the garage all the time.
I don't like a stud wall because I might have to get a building permit, it will take up an additional 4", and I can't return the garage to the original configuration if I sell, at least not easily.
I haven't thought about ventilation yet, but it will have to be completely independent of the house ventilation system or my wife will experience remarkably unusual emotional transition.
Thanks for the answers.. I also have a three car garage with one bay being my workshop. Below are some of my thoughts for what they are worth..
Pros of building a wall:
In my neck of the woods, you need air conditioning in the summer, and heat in the winter, if you plan to enjoy being in the shop. I use a window unit for air and an oil-filled electric heater for heat. Both work well in my single car garage, but neither would heat or cool all three bays.
A normal garage has one or two AC outlets, not near what you need in a shop. Adding a wall gives you a place for these outlets.
Wall space for hanging things is also another reason to build a wall.
Keeps the dust out of the house and off your cars
The effort to build a 2 x 4, non structural wall, including a door would be minimal.
By having a wall you don�t have to worry about kids, or grandkids, messing with your stuff unless you want them too.
Cons of building a wall:
Building a wall somewhat restricts what you can build in your shop.
The layout of your equipment is limited as you will only have about 10 to 12 feet in width to work with.
It is nearly impossible to cut up a full sheet of plywood in a single car shop, assuming that you have other things in the shop besides a table saw.
Any wall would most likely have to be removed when selling.
Without a wall, the shop could be expanded to all three bays, even if it were just temporarily.
