ADVERTISE HERE - FREE TRIAL
Wooden "wagon" wheels?
I now have to build Tevye's milk wagon. Anyone know of any good plans for wheels?
If I do it in a "brickwork" way, I can take 2 x 8s and make an octagonal outer frame. I could cut some spoke mortises in the outer frame. I could then make the hub (also octagonal) and then make cut mortises in the hub. The spokes could either be dowels or rounded pieces of the 2 x 8. I would then glue it up. I'd then mount the wheel on a jig and trim it on my bandsaw.
My other thought is to cut the wheels out of plywood. If I do it this way, I'd probably glue two 4' x 4' sheets together and cut the wheels out of that. I'd have to use a jig saw to cut out the voids between the spokes. Another thought is to kerf bend a "tire" around a single thickness of plywood.
So, any thoughts? TIA.
BTW, the budget for the props/set is SMALL. Buying is not an option.
Re: Wooden "wagon" wheels?
How big?
Lee Schierer McKean, PA
How big do they need to be and what sort of weight do they need to carry?
Lee
I've never done it, but it would seem like the hard part would be getting those spokes set in place in the wheel and hub. Could you build up the rim from 1x stock, cutting half your mortise in each 1x and then capturing the spokes as you face-glued the 1x stock?
Or build your spokes heavy enough that you could do what amounts to a loose tenon, holding the spokes in place while drilling through the rim and into the spoke for a dowel?
Sounds like your theater group is a source of constant challenging fun for you.
Norm made wagon wheels for some sort of Tea Cart. Might try looking that up.
I would do something like cutting the rims out of two pieces of 1 X ? and offsetting the joints. Then make a jig to route with a core box bit. putting half a round hole inside each half and then fasten them together with a dowel in the holes.
Or, you could make up solid rims and drill holes through them and drive the dowels through.
Nat Robison
I would go the plywood route. My mom was in a production of "Fiddler" recently..........the cart doesn't need to carry any weight. I would cobble together any wheel-to-cart connection that I thought would withstand whatever abuse the cart might take in a stage setting. I think most competent carpenters could build a cart that would fit the need. If I recall, the cart in my mom's production was only in 3-4 scenes.
Most carpenters would probably want to overbuild this, as though it would see real action on a rutted road in 1917 Russia. Yours will be indoors, on a wood floor, and appear for 10 minutes onstage. I'd spend more time painting and glazing it to look old than I would fussing about its construction.
Just my opinion..........
3'-4'
But if you build it, they will use it
for other productions. :D .
I'm leaning towards plywood, simply because it is easier.
George Colonel's Workshop-Havertown PA
Good Afternoon JL,
I would go the plywood route and not look back. It'll be just as effective visually and take considerably less time and expence to make.
George
Bill Howatt
I made some 3' dia, 12 spoke wheels for a decorative garden cart planter.
I made tapered spokes from softwood 2x2s.
I made the rim in 12 sections of softwood 2x4s. The spoke hole was in drilled in the center of each section before it was glued up using 2 biscuits and either epoxy or polyurethane glue. The outer edge was made into a circle with the bandsaw but the inner edge was done with a jig-saw. Edges were rounded over with a router.
The hub was made of softwood 2x6s glued up, cut on bandsaw and shaped on the lathe. Then the 12 holes for the thick end of the spokes were drilled.
The spokes were of correct length so the glue could be applied to them and then they were slid down into the hub. They were then pulled out so the small end would slide into the hole in the rim.
(BTW, the System West epoxy from LV has stood up better than the polyurethane glue.)
The real salient feature of this long-winded description is that I told my wife should anyone want me to make wheels for them, the price would be around $500 per wheel - it was a lot of work. I like the ply idea.
Bill
Jason Roehl in Lafayette, IN
A quick and dirty option...
Since you mentioned using a plywood sandwich for the wheels, how about making it 3 layers thick? Make donuts for the outer two layers of the wheel, but make the middle layer one piece with spokes. Then you could rip dowels of the same thickness as the width of the spoke and glue them to the face of the plywood spokes.
Jason
Make them like they used to
Forrest Addy
It' not hard to make wheels with a hub, spokes, and felloes all pulled together with a hrunk-on hoop. I've built everal sets for stage productions and, trust me, a band saw and a poke shave makes the whole operation so simple.
Naturally you have to do some research, plan your work, maybe work a little math. The alternative is to do it some "simple way that's weak, ugly, and in the end more costly in terms of time and labor. The wheelwright's trade was once a major factor in a community's life.
There's good reason why wood wagon wheels were made the way they were, and why wheeled societies all over the earth used roughly the same methods to make them: it's the simplest and the product of a thousand years of craft evolution.
There's a book and if I find it I'll post a link:
Sounds interesting.
Exactly how I made them 10 years ago
David McDonnel
I did the plywood sandwich. 4'x4', cut out the middles with a jig saw. added a 3rd layer on the outside and hub. Cut dowels in half and glued them to the flat spokes to make them look round. Added a 4th layer to the hub on the inside to space it out from the body/frame. Those original 2 wheels and another two I made years later were reused for a buck board wagon and then that wagon was morffed into the Surrey with the fringe for Oklahoma then finally back to a buckboard for Wizard of Oz farm scene this last year!
