OT - roof flashing question
DouginDenver
I have a two-story brick house with a one-story addition off the back. The addition has only a slight pitch to it, so the roof of the addition meets the brick back wall of the house at maybe 5 degrees over 90. Where the roof meets the wall has always been a leakage problem. Currently the roofing is just run up the wall a couple inches, with lots of roofing tar behind it and over the edge - no mechanical flashing. The sun bakes it and it cracks. So I want to redo the roof.
If I go to Home Depo type places, the only flashing I see is a strip of galvanized bent at 90 degress. That doesn't seem to be the answer because I can't see how to get a tight seat to a brick wall. On This Old House they use a strip of soft lead and put it in a mortar line of the brick. That is a lot of work, and my mortar lines are the real thin "bread and butter" type, so I would not be able to add mortar to hold the flashinh in. When I look at new roofs around the neighborhood, they seem to flash chimneys with an aluminum channel with some sort of rubber seal in it that is screwed into the chimney. That seems hopeful, but I've never seen it for sale or seen it close up. So, how does one flash a slighly pitched roof to a brick wall? Thanks.
