ADVERTISE HERE - FREE TRIAL
Standard dimensions of tongue and groove boards??
Jesper, Denmark
Jesper, Denmark
I have just ordered 1000 sq. ft. of 5/4 tongue and grooved boards for the new floor in the loft of the shop. The boards are planed and have t+g sides, but plain ends.
It looks like the tongue and groove dimensions ar 0.325 inch, which seems a weird dimension. Is this a common tongue size?
Actually the boards are 35 x 200 mm raw, and 29 x 135 mm as finished - metric sizes, but still derived from the "old" inch dimensions. I will need to cut the t+g in the ends with a router, hence the question of getting the right size bits.
Re: Standard dimensions of tongue and groove boards??
It doesn't matter.....
Those dimensions seem a bit large to me. I suspect the mill used the same cutters they would have used if you had had 1 1/2" (2" nominal) stock milled. Without being scientific, I always thought the tongue should be slightly less than a third the thickness of the piece and slightly low of center. Lowering the tongue allows for sanding the surface without getting into the the T&G. They often cut the pieces so that the bottom shoulders were slightly narrower than the upper shoulders so that the pieces would pull up tight on the top. (Gave me a fit when it was the floor above and the ceiling below.)
As for the ends, two things. Either don't bother to end match them or use any set of cutters you want. They don't have to match the edges, they won't show. I built a number of houses with 2x6 pine flooring and the ends were never T&G. But, the flooring was laid over beams on 32" or 3' centers and the ends always fell on a beam.
All those dimensions...
... sound odd to me. 35mm is 1 3/8", not a */4 size (not 5/4 and not 6/4--okay perhaps a "fat 5/4"). 29mm is just over 1 1/8", not a common finish flooring size on this side of the pond. And .325" is 8.255mm, not a standard metric groove size. So your best strategy is to buy a set of stacking grooving cutters and an arbor and whatever bearings and spacers you need to configure tongues and grooves that match the t&g on the long edges of your boards. If you're just doing the ends, you could certainly just use any standard tongue/groove dimensions that you like, since these end joints don't technically have to match the long ones.
Jesper, Denmark
Re: All those dimensions...
Jesper, Denmark
The inch to mm dimensions for the finished boards and the original rough cuts may have an explanation. Just like when metal threads were converted to metric dimensions, particularly the pipe threads, the old inch sizes were in fact retained, just called a mm dimension. As an example, 1 �" pipe is called 15 mm in ISO designations. The hole in the pipe is NOT �" and NOT 15 mm - and never really was. The hole diameter varies with the pressure rating, and to only standardization is the OD of the pipe and the thread.
That was the long way around the explanation, but the wood sizes may in fact also just be a "convenient" mm dimension close to the original inch sizes. 5/4" is 35,56 mm - not a term you can use in daily spreach, so it has become 35 mm. The board widthe is called 200 mm, but may really be 8" = 203,2 mm.
To add to the confusion, when I was a mere lad, there were different "inch" sizes here in Europe in different countries. All derived from different longer length measurements.
It still does not solve the tongue size mystery, as it will have to be made with modern milling tools.
Jesper, Denmark
Re: It doesn't matter.....
Jesper, Denmark
Good idea that the milling does not need to be the same as the sides - hadn't thunk of that.
The do need to be milled in the ends, as I am stretching the size the boards should span. The beam center distance is 44 inches, so I do not want to just butt the ends on the beams. The two spans on either side of the butt are weaker than if they are coped together in the ends.
BTW the old floor is only 1" planed stock, some plain, some t+g, some a varied mish-mash of siding boards and a few old doors, so you could get seasick walking too much on it.
Paul Dzioba
I would just mill grooves and make loose tongues with the grain orientated the same as the boards. Thickness plane a board down to the groove size and cut-off the individual tongues. Maybe use a biscuit machine?
Paul Dzioba
Jesper, Denmark
Jesper, Denmark
Good idea with only cutting the grooves. It saves having a two router set-up. It further helps as the two routers I have are different voltages - one Festool 220 Volt and a Porter Cable left over 115 Volt - but I do have both in the shop, Voltages that is.
I doubt whether the biscuits would be strong enoug, though.
FredD
"The two spans on either side of the butt are weaker than if they are coped together in the ends."
In what way ? , the strongest possible support for the end of the boards is a butt joint , cut square and the joint centered on the beam or joist.
The only stress worth mentioning on the boards is directly down.
The reason for the end match is to keep the top surface of both boards flush.
I would think the Biscuit cutter would easily do that and save you a lot of milling.
If you still doubt the Biscuit , use a 1/4" slotting cutter in your router to cut the groove and make the loose Tenons out of 1/4" Plywood.
FredD
Jesper, Denmark
Jesper, Denmark
Hi Fred,
I was maybe a little imprecise in the statement. A butt joint on the beams is not as strong as the span of an un-broken board across the same beam. In the butt joint, the fastening on the beam act as a hinge if you like. An unbroken board adds stiffness to the part on the other side of the beam.
Without t+g in the ends of the boards, you have to make the joint on the beams - and stagger them of course. With t+g, it is unimportant where the joints are, and you can just let them be where the board lenths dictate. This is common flooring practise. It also saves waste and time.
Since this is an old building - 1928 - with the structural lumber selected from whatever was liocally available, the distance between the beams are not all the same, so having the joints on the beams will require cutting every board to length. There is 1200 sq. ft. of floor, so about 190 boards, 16 feet long.
I think I will be tired before all this is done!
Jesper, Denmark
Re: Decision........
Jesper, Denmark
I think I will cut the t+g in the ends with whatever cutter that gets close to the 1/3 thickness of the boards. That it is not necessary that the end t+g is the same as the sides was something I had not thought of.
Thanks for all the commentary.
I still haven't figured out where the weird tongue dimension came from.....
Kneale Brownson
Kneale Brownson
Maybe the unusual dimensions come from the mill having cutters reground.
The only time the ends and sides need to match is if you're laying something like a herringbone pattern.
Personally, I'd go the biscuit route.
FredD
Jesper, you must pardon my slowness but it seems to me that your saying you are going to lay flooring directly on supporting joists or beams with no subfloor between.
If that is the case you definitely need to land the joints on a joist.
If the boards reach from end to end without a joint, why sweat a end match?
If you are going over a subfloor , why use 5/4 that is twice as thick as common hardwood flooring?
FredD
Jesper, Denmark
Jesper, Denmark
Fred,
The building is a 1928 built storage building, originally used as a beer distribution store. Brick walls and pole barn rof construction with 6x8 inch beams on more or less 40 inch centers. It is 44 foot long and 28 foot wide.
There is no sub-floor, but there is 4 inch insulaton under the old floor, which is a mix of various 1 inch boards in poor condition from powder post beetle-like infestation of insects. The structural timber is both in good shape and treated with Boracol, but the floor has to be replaced. The choice of pine t+g was price.
It is only used for storage, so the standard codes do not apply, wihich would have requirede at least 1� inch boards for the span. Adding joists between the beams is not practical, as it would mean a total re-build of the structure - expensive and time coonsuming and unnecessary. all the boards will be 16 foot long, so three boards ened to end will cover the length and can be trimmed to have all the ends land on beams - staggered of course.
I suppose you could call this a late life crisis project - I will finall retire later this year and have some health issues, so one of the drivers to do this is mabe to prove to myself that I can do it.
Jesper, If you can "make" the ends land on a beam/joist without too much waste and fuss, that is definitely the best way to go. You may be able to set up a sequence of three or so runs and just repeat as necessary to cover the floor. Even alternating two runs would be satisfactory for a storage floor.
It might be more economical of the material to ignore the beams and let the ends fall where they may, but it would be better to end math them if you do. I would use a tongue that is about a quarter the thickness of the material to leave the shoulders of the grove a little stronger. I picture the groove failing long before the tongue does. I probably would use biscuits or set up a router with a 1/4" (or metric equivalent) slot cutter and cut slots in both matting ends and then mill a piece of lumber into floating tenons. I would cut those so the grain is parallel to the grain of the boards. You could mass produce this. Cut all the boards square if necessary, Cut the end grooves in all of them and make the floating splines in advance.
Another possibility is to lay a board and then screw a piece of blocking under it to support the ends. You could use a piece about four by eight and put screws into both he end to end pieces and on each side. this would clearly be time consuming, but you could decide which is more valuable to you, your time or your material.
Jesper, Denmark
Well, here is the set-up....
Jesper, Denmark
By adding a 90� fence on the Porter cable and a 1/4 inch straight bit and using a rabbetting bit on the Festool, the T+G can be easily cut. The major draw-back is that the groove fills up with chips and need cleaning out each time with a screwdrive or something..... no problem, just slows down the process.
Lee Grindinger
Those look awfully deep
Lee Grindinger
I confess I'm late to this thread but if it's flooring you're making the tongue need only be a quarter inch or so wide. The depth will weaken the groove as well. Additionally you're losing more width per board than you need to.
Lee
Jesper, Denmark
Re: Those look awfully deep
Jesper, Denmark
The T+G are already on the boards, except for the ends. It was cheaper to buy 5/4 boards, planed and the tongue and groove cut on the sides - but not on the ends.
The original post was to see if the dims were something standard - and issue yet to be resolved.
I am only cutting the T+G on the ends.
The T+G are basically 0.325 x 0.325 inches on a board that is 5.30 wide, 1.15 inches thick as finished.
Lee Grindinger
Well...,
Lee Grindinger
like I said..., late to the game..., good luck with your project.
Lee
Re: Well, here is the set-up....
Looks Good. If it works for you, go for it. OTOH, I tend to agree with Lee. I don't think the end match needs to be More than about a 1/4" I would have used a wing cutter to keep the router cutting the groove Vertical if that's the right term. I probably would have used a quarter inch wing cutter on both pieces and put in a spline.
