Quasi OT Sticky Window sashes
Alan Young
Alan Young
My son is buying a house. The windows are wood but have a metal slide . The sashes are somewhat sticky. Is paste wax an OK product for lubrication in this type of situation? If not what would be best?
Thanks
-Alan
Here are some pics-
Re: Quasi OT Sticky Window sashes
In my experience, paste wax is almost always OK, IF you rub it out so that there's just a thin layer of wax. I read somewhere that wax sticks very well to other things, but not so well to itself, which somehow has to do with why it's slippery. So, if you wipe off all the excess wax, there'll be nothing for any dirt to stick to.
Use furniture paste wax, not automotive wax; the car wax contains fine abrasives to bite through oxidized paint, and might not improve the action on the windows.
An alternative would be one of the dry lubricants (in my motorcycling youth, the big name in these was Dri-Slide, used extensively for the brake/clutch/accelerator cables), but these usually are packaged in a liquid carrier of some kind; might be hard to apply without making a mess.
I found a "teflon" spray lubricant that works quite well. I use it on the lights at the theatre. I like it better than wax.
Not sure what to use, I would look at paste wax or talc, but I can tell you what not to use, and that's silicon spray. It appears to work for a minute or two after you spray it on and then it softens the paint and they stick worse than before. So, I would be very careful with any spray and I would do one window and test it for a few days. Cleaning the paint off the metal tracks might be good also.
Jesper, Denmark
Jesper, Denmark
Automotive wax may also containe silicone - it make the painting a problem later on.
