Angled tenon making?
Tony - Memphis
I'm building a couple of chairs. There are no 90� angles on these things! I've figured out ways of cutting the angled tenons, but nothing I'm happy with. Fo the exposed joints, I cut them close and then finished them with a chisel. That works and might still be the best way to go. For the parts like the backs that will be covered, I cut the end of the stile to the appropriate angle (2� in this case), then just used my tenon jig on the TS to cut the cheeks and nibbled away the rest out to the shoulder. Not pretty, but it works ok. Anyway, just got me to wondering what other folks do. I've seen a couple of router jigs that looked interesting. Just read an article y Pat Warner on his jig to do tenons. I guess regardless of the technique, fitting by hand will always be required if you really want tight joints. That's subjective I know, but I like to try and get them really tight. I'm not always successful, but I try! I don't have any pictures with me of my progress, but these chairs are my take on a lolling chair. I used lots of pic's on the web, Norm's plans, etc. and came up with my own design using Sketchup. I'm still tweaking the arm design. Almost ready to start on those. The backs are getting close to being finished. Just need to bandsaw the curves and then glue them up.
So, how does everybody else do their angled tenons (or straight ones fo rthat matter). Oh, for straight, I use teh Delta tenon jig for the cheeks, cut the shoulders with the miter gage, and then tweak by hand. When I took a class with Phil Lowe once, we had to chisel the tenons on all four tenons for the sides! That was too much!
Tony
, but something to keep in mind for next time. It can also be a tricky problem to solve, but its stronger when you're done. On some designs you can keep the back leg square to the mortise and let it be angled relative to the front of the chair. Some of this stuff gets much, much easier with hand tools of course.
