OT - a workshop framing question
I'm converting a shed I built some years back into a workshop with finished walls. Simple gable roof. Cathedral ceiling (my sweetie finally gets a space with a cathedral ceiling), with 3" of sheet foam insulation in a 2x6 rafter bay and 2-1/2" of ventilation space above the foam; each rafter bay will be ventilated at the soffit, with a ridge vent on top.
The rake walls are built on top of standard double-top-plate walls. At the moment, there's no barrier between the rake wall cavities and the adjacent ceiling cavity. Is it necessary/desirable/code to install 2x stock in a manner that isolates the rake wall cavities from the ceiling cavity?
Re: OT - a workshop framing question
Rafter Bays
Bill, if your concern is "code", check with your local bldg. dept.
Are your rakes carrying a rafter or are you using them for direct roof sheathing support? (seen it both ways)
Re: Rafter Bays
The rakes carry a rafter and some lookouts for the extension of the roof for the gable (Victorian house).
Re: Rafter Bays
Don't see a problem here, except, perhaps for the need for a nailer for your ceiling surface material, but again, California "code" may vary; gotta "ax da main."
