Bowling Lane Sections
Saw this on Craig's list. I have a couple of bowling lane work benches. They work well. Sometimes folks are looking for these so I thought I'd pass it along.
http://chambana.craigslist.org/for/1803387268.html
No affiliation.
T.
Re: Bowling Lane Sections
PS.....
If anyone buys any, let me know if you need some tips on how to work with them. Happy to help.
Tom
Been there, did that ....
Rich Pearson in Mill Creek, WA
and got a good bench top!
If you do buy a section, be sure that there are lateral (side to side) slats nailed to the bottom of the section every 2-3 feet. Without this support, the section may flex, curve or bow laterally, which will crack the top finish. It looks like a solid slab but there is a LOT of flex possible if it is not reinforced.
Usually the bottom of the lane section is irregular (not flat from board to board) so it would be a good idea to rout some dados side to side to provide a stable support from a common reference thickness for the slab when you build the legs/frame supports.
Another thing to consider is that the boards are glued and NAILED (lots of nails) together, so drilling bench dog holes almost guarantees that you will hit nails every time. Choose a tough and disposable drill (probably several bits will be needed) and plan on some holes wandering off couse from vertical.
A meaty hardwood surrounding frame will allow face grain attachment points for the vise(s) of your choice.
Big Dave
Just a note to add that not all lanes are glued. The sections I bought several years ago were just nailed. Nailed very well, but "just" nailed...
