Pacemakers and Woodworking
George Colonel's Workshop-Havertown PA
Good Morning friends,
Gary asked about the effects my pacemaker had on my woodworking. Rather than respond to his question under the "Happy Fathersday" thread a few posts below, I thought my response in a seperate thread would be more appropriate. Gary and I are not the only people in our wood working group presently equipped with pacemakers, and there are bound to be more wood workers who will require them in the future.
Gary, I have a simple pacemaker, and not a defibrillater. It was installed about 2 1/2 years ago after I experiences some faintness, and actually passed out while painting my shed. I had a heart attack and quintupple heart bypass surgery in July 1999, just after I retired from my civilian job. I was doing pretty well in the interim, and spent most of my time in the shop.
I was told to expect no problems with wood working and associated machinery, and to use common sence around any magnets I may be working with. In my shop, I use a few magnets to retrieve metal screws and debris from the floor, and to help align/mount accessories like a "tilt-box", feather board, and bandsaw light. I prefer to use rare earth magnets to secure furniture doors. These have no effect--but then I don't put them intentionally next to the pacemaker. Any electrical field which may be machine generated was felt to be too far away from my pacemaker to have any influence. So, there is no real constraint on my wood working. I will say that without one of these devices, I would be a danger to myself and others because of dizziness/black outs.
Most of the time I don't know I have one installed under the left shoulder, and the bulge has reduced. If you receive any cautionary advice, please post it for the benefit of all. Good luck and enjoy the shop.
George
Re: Pacemakers and Woodworking
Another electronic woodworker-kinda long
doug f, san clemente, ca
George/Gary:
I, too, have an ICD which keeps me from falling headfirst into my table saw. I've had it about 6 years and have had no trouble with it at all.
I had the same concerns about magnets and so on, so I have had several "heart-to-heart" :D discussions with my doctor, who is a cardiac electrophysiologist, and also with the manufacturer's rep who checks it 3 times a year. They have both told me that the electromagnetic fields generated by a table saw, jointer, etc., are probably not strong enough, nor close enough to cause damage or a malfunction in the ICD. If my physics class serves me correctly (a huge assumption) the force of a magnet decreases with the square of the distance, so that 18" to 24" from a small motor is sufficient. They both cautioned me to stay at a more respectful distance from car engines, especially diesels, and avoid electric scanning equipment (airports in particular.)
Like George mentioned, after a few months you tend to forget it's there and worry more about how to get the d**n dovetails to fit!
Good luck with yours and enjoy your woodworking.
Doug
Re: Another electronic woodworker-kinda long
glh17
Thanks to both of you guys. I've been researching this topic wanting to know something about it before I talked to my doctor, but I wanted to hear from woodworkers who actually have one. My guess was the tablesaw, drill press, bandsaw, jointer, planer, and router under the table where probably ok, although I did read somewhere a recommendation of no power tools. My primary concerns were about those fairly strong earth magnets used as featherboards and handheld power tools such as routers and drills (more with the router than the drill because of the distance from the ICD).
Thanks Again for your responses,
Gary
Well Gary,
I do use my router under the table, primarily. But also in a free hand mode, including plunge work. Initial positioning puts the 10 amp P+C motor almost against the pacemaker, and it hasn't had any effect.
George
glh17
That's good to know. I use my handheld routers quiet a bit and it would be hard for me to substitute a tool in a lot of cases. By the way, I'm glad you started a new thread for this. I suspect quiet a few woodworkers either have or will have pacemakers and would like to know how others have dealt with it.
thanks,
Gary
Just to put your mind at ease...
Gary - when I was asking all my questions, I asked about routers, jig saws, drills and sanders, small motors in general. The Biotronix rep, who it turns out is a budding woodworker, said that company tests had indicated that small motors like these didn't generate a large enough field to affect the device. Again, distance pretty much negated the effect.
Since my device is an ICD and a cardiac monitor all in one (ain't electronic miniaturization grand?) his only concern was that the motors might influence the monitoring records, but no compromise of the device itself was evident in their tests.
Relax, make some sawdust, then go have a tall one.
Doug
Re: Just to put your mind at ease...
glh17
Doug,
Sounds great! Maybe I can make a little dust before long. I've got a long list of requests that have accumulated over the past couple of years. I just didn't feel like doing anything when I got home from work.
Hope this thing works!
Jesper, Denmark
Jesper, Denmark
Hi Doug,
I am curious about the emphasis on staying away from Diesel engines. Did they explain to you why?
Gas engines generate high voltage frequencies from the ignition system, but diesels were purely mechanical up to a fw years ago and now still mostly mechanical, but with an electronical control of the injectors.
I would have thought there are fewer magnetic or RF emissions from a diesel than from a gasoline engine?
The tech was more concerned about BIG diesel engines, large boats, tractors, that sort of stuff. I wasn't real worried about that since I'm not a mechanic and deal mostly with very small electric motors.
The devices work very well and for the most part are bulletproof.
Doug
Gary Bindel
I've had my pacemaker for five years now after two mitral valve replacements and a maize(sp) procedure. I have had no problems with it when doing anything. I've even accidentally zapped myself when working on a breaker panel. What I find most amazing is the tremendous amount of information it stores that then can be retrieved to see how well it and your heart is working. I occasionally have atrial tachacardia and they can tell to the minute when it occurred and for how long. My only complaint, is that sometimes the car seatbelt doesn't feel too good on it.
glh17
I know what you mean about the seat belts. It's only been 2 weeks since my implant so I still have a pretty sore wound. For the time being, I'm taking my chances on a tick-it rather than click-it.
I'm sure glad to hear that some of you are still able to work around woodworking machinery without problems. I have quiet a bit of equipment for a two-car garage shop and would really hate to sell it right now. I plan to retire in three or four years and plan to spend a lot of time in my shop.
