Fixing old drawer dovetails - need suggestions
Joe in a Cleveland suburb
Hello,
The pictures below show a drawer that is from a chest of drawers that belongs to my 80 year old father. I told him and my mother I would try to fix it for them. Apparently, my fathers uncle made this many years ago.
Anyway, from the pictures you can see the dt's have come loose. I would like to try and fix this without it looking like I fixed it.
Are there any clever tricks for this kind of repair? Glue alone probably won't work because of the gaps that have formed. I thought about PL Premium construction adhesive, but then I thought I should ask here first...
Thanks in advance for any suggestions!
Re: Fixing old drawer dovetails - need suggestions
FredD
Joe, , you should get a acceptable result from using Yellow glue and some judicious clamping.
Construction adhesive is formulated to stay somewhat flexible and would not be a good glue for this type of repair .
One of the pics looks like some Dutchmen have been inserted , you might have a better fit if you could remove them.
FredD
jmccull
It appears that the dovetails are generally fine and the use of a yellow glue on a thin pielce of wood should get enough glue in the openings and clap with cauls between the dovetails if they stand proud. The bottom of the drawer is a different problem. It appears that it has been worn enough over the years that it has broken out where the groove for the bottom is the thin spot. It appears that it has been repaired with brads at sometime in the past. It needs some more serious work. I would remove the side with ginger taps from the inside with a happer and a block of wood. I would either plane beyond the dado or use a table saw to cut the worn portion away and glue a piece of poplar to make the piece back to the original size. You will need to recut the groove with your table saw or a plane.
You probably need to check the drawer runners that the drawer runs on they will probably need to be replaced as well. I always saved the original drawer bottom piece and the drawer runners and put them in the area of the case where the runners are as proof of origin.
There is more than meets the eye here. If the piece has historic as well as sentimental value you want to make "appropriate repairs". Perhaps someone with expertise in restoration will chime in. One thing for sure, do not use construction adhesive. I love the stuff for other types of work, but it is totally inappropriate here.
Liquid hide glue or better still hot hide glue would be better.
I do know that the makers of antique furniture used softer wood for the drawers and harder wood for the runners because it reduced the friction and to cause the wear to occur on the drawer, because it is easier to repair the drawer than the runner.
I think it is considered acceptable to cut away the damaged portion of the drawer side and add a new piece to restore the edge. Not sure, but I think it is acceptable to cut very thin slivers of matching wood (veneer) to fill loose dovetails. There is a company locally that restores and sells antiques. If it is important to you I can go by there and see if they will give me some pointers and pass them on to you.
Not only does making appropriate repairs help to maintain the value of the piece, they are excellent workmanship and work well to restore the integrity and usefulness of the piece.
You might post your question on the Hand Tool Forum (under Messageboards) and see if they don't have better pointers.
Agree...
John in NM
Hide glue is the way to go, if for no other reason it is repairable later. If the piece was originally glued with a PVA, you'll have to clean off the old glue before attempting to fix it, as new glue (not even the same PVA) will not stick to it over the long term. Hide glue will stick to itself making repairs fairly straightforward.
As to the broken piece, I'd attempt to glue and nail it myself, but cutting it off and replacing would also be an acceptable option. You could make a European style runner if you want, where the whole drawer side bottom (from dado down) is replaceable.
I've found construction adhesive to be a vastly over-rated product, failing within a few years, and little better than most caulking products. But then I don't use it often, so my exposure is limited.
paul in AZ
My guess is that using some sort of adhesive alone to give it the appearance of not having been repaired will not give you a strong,stable result. I would be tempted to rebuild the dovetails by shaving some old wood away from whichever part is crumbling to create a fresh even face and glueing in a dutchman, then fitting and reassembling it in the usual way.
This based on the premise that the piece has more sentimental value than 'historic'. The rest of the piece is what people will see for the most part and drawer dovetails repaired in this manner won't detract from it's appeal. If this was of museum quality and importance the approach might differ.
SlashDev
While the pins are fairly narrow, a sign of hand tool skill, the last photo shows how the corners of the tails can break off when the angle is too steep. It looks like the front is one big DT, too, which would allow the face to possibly cup.
One reason that the side split is because the back-to-side DTs are going the wrong way. The side should have the DTs, not the pins. Over time, the side pulled out of the back, allowing the drawer bottom to fall out of the groove in the front. Now the weight of the drawer contents is only supported by the sides, not the front.
Now to repair it, I would also suggest liquid hide glue. That's probably what's on it now. Moisten the joints or use a steam iron, then gently tap a block on the inside to disassemble the drawer. I'll guess that bottom is nailed to the bottom of the back. Pry that loose when the back is removed.
To fix the DTs, first clean up the joints with a moist sponge or tooth brush. Then I would chisel off the just enough of the corner of the broken tail to get a nice flat facet to glue on a new piece of poplar. After the glue dries, re-mark the tail (from the side pins if necessary) and re-form the tail.
To fix the split, I would just glue it back up to the side. Once you get the drawer bottom supported by the drawer front, this sliver is not as structurally important.
If the bottom is still too flimsy when inserted into the groove in the front, a "drawer slip" could also be added to the inside, bottom edge of the side. A groove in the slip would fully support the bottom, the 1/2" to 1" tall slip is glued to the side, the bottom of the slip provides extra weight-bearing surface for the runner, and the sliver can be glued to the slip. No new wood outside, so it looks pretty original.
In the long term, the real problem is keeping the sides from pulling out of the back. We're getting a little fussy here, but I'd also consider either (1) wedging the pins into the tails, or (2) cutting the pins off the sides (losing 1/2" of drawer length) and cutting tails into the sides, placed so that the new pins can be cut in the old tails that are currently in the back.
HTH!
/dev
