Lawn Mower won't run long question? OT
Put my John Deere walk behind mower in the shop for a tune up. Got it back a couple of days ago and let it recover from eh trauma for a few days in the shed. Tried to mow the grass just now and it ran for about three minutes and cut off. Started it again and it ran for about three seconds. Did that several times. Have to wait a minute of two to even get three seconds. I'm not an engine guy, but seems to be starved for gas. The "gas" is "on". The gas is fresh and clean. Anything I am missing?
It does back to the shop tomorrow. Sure would like to get the grass mowed though.
Re: Lawn Mower won't run long question? OT
Pop the top
Dustmaker Mike
Undo the gas cap. To see if it will run longer. If so you are getting a vapor lock on the mower. I have had several small motors do this in the last few years. I replace the gas cap and away I go.
Jim DeLaney, Austintown, Ohio
Check the gas cap, like Mike said, and if that doesn't fix it, take a look at the fuel pickup in the tank. It should have a very fine brass screen that may be clogged.
Also, if there's a rubber fuel line, and you've ever used 'gasahol' fuel, the alcohol may have swollen the line and choked it off. If so, you'll need to replace the line.
Jim D.
Rats...Knew it couldn't be that Easy..
Went out and loosened the cap and yanked the rope. Off it went, for about three seconds.
This is a double insult. It was running fine when I took it to the shop for a new belt. Decided to get a tune up while it was there because it has not had one in years. Thought fresh oil and a Tune up would make it run smoother.
The shop called and pointed out it had front wheels going bad and the back ones were slick. So, they proposed to move the back ones to the for and put new ones on the rear. OK. Just did not expect it would take $72 worth of labor. Apparently they billed an hour, no matter how long it took. They also billed an hour for several other things. So they bill the projected rate unless it takes longer and then they bill the actual time.
2 cycle or 4 cycle ??
del schisler
if it is a 4 cycle Make sure it is not over filled with oil ?? the vent from the crank case vents into the carb. If it is getting oil it will quit But it will be smoking a lot I have fixed a few that have been over filled ? A 2 clcle the small hose's are a problum Make sure their are no break's in any of them Check where they go on the carb and make sure they are tight their On the end of the fed hose their is a round look's like a ceramic piece which soak's up gas see if it is loose or came off?? And the hose is just floting out of the gas ?? good luck
Re: Rats...Knew it couldn't be that Easy..
bill kay
I have had similar problems with my current mower. Each time the fix was one of the following three choices.
1. Plugged vent in the gas cap.
2. sticking float or partially obstructed float valve
3. plugged fuel transfer port. Look at the float bowl. On many of the carbs the brass bolt that holds the float bowl on also functions as a metering orifice for the fuel before the main jet. While you are checking the float make sure these passages are clear.
Hope this helps
Fuel "ON"?
Tony - Memphis
My Honda has a fuel cutoff switch. I have tried to start it with the fuel turned off! Runs for a minute.
Tony
Re: Fuel "ON"?
Yes the gas was on, at least the switch was in the position that indicated the gas pump without the slash through it.
I hate those "international" symbols. I would have thought they sold enough mowers in this country that they could have labeled it in English......and Spanish.
I took it back to the shop today. The good news is they couldn't get it to run either. Wait, That may not be such good news, but at least the little piece of crap did not run like a champion and embarrass me again.
