Stubborn stain
Dave in Haverford PA
Am refinishing a table top and having difficulty removing the old finish. Have used paint remover several times and applied oxalic acid several times but the dark red stain hangs on. Any suggestions?
Stubborn stain
Re: Stubborn stain
George Colonel's Workshop-Havertown PA
Good Afternoon Dave,
You might apply a little clorox bleach to the spot.
George
Re: Stubborn stain
FredD
Removing old finish with Paint thinner won't work.
You need a stripper.
After it is stripped of all of the old finish and the stain remains , get a two part commercial bleach for wood , it has a strong Hydrogen Peroxide as one part , so be careful and use long rubber gloves and apply to the entire top, so you will end up with a bone color that accepts any stain
FredD
Re: Stubborn stain
Howard Acheson
Oxalic acid is a wood stain used to remove black chemical and mineral stains from wood. The bleach you want to use to remove the residual dye stain component of your stain is a chlorine bleach. A fresh bottle of Clorox mixed about one part Clorox and five parts distilled water should work. Flood it on the whole surface and keep it wet until the stain is reduced to where you want it.
