We value your privacy.
I just put a new floor on my deck about a month ago. Treated pine. Some of the boards have marks on them apparently left by the fork lift at the lumber yard. We put them with the "pretty" side up, but in some case the dirt and rust are on the top. I am wondering about using my ROS to sand the spots a bit and clean them up. Good Idea? Or is there a "skin" of chemical that is a little heavier on the surface that sanding would remove and then the sanded spots would age faster?
Actually tried to do that, but some of them were just too bad on that side and had to turn them over. Wish I had bougth about 20% extra to alow a little more picking and choosing. Had a few and cut them up for rail parts.
To get the best possibe 2 X 6's for the cap rails, I bought 2 x 12's and ripped them. I went through all the 2 x 6's they had at Lowe's and every one of them had the pith or an obviously crooked little tree in them.
Barry , I don''t know how your fixed for lumber yards , but buying lumber at big box stores is a pitiful exercise in self flagellation , once you start using it. ;-))
they actually grade lumber for the Borgs. Do the suppliers set aside lumber of somewhat lesser quality (right at the bottom limit of the grade) for Lowe's and Home Depot? Part of me says no, but part of me wonders. It sure does seem that the lumber there is worse than at the local yards. You might think it would be the other way around, that the big box stores could use their huge buying power to get the best, but apparently they don't.
Unfortunately, I have a Lowe's about a mile from the subdivision I line in to the right and a Home Depot about a mile to the left. The "real" lumber yard is about ten miles away and an even better one about thirty. They don't allow you to pick through the lumber and they charge for restocking.
I know the roofing materials from the same manufacturers weigh less at the borg, I've had plumbers tell me the borgs get their own lines of cheaper fixtures from the suppliers, you almost never find as good a grade of lumber, etc.
Barry ,I never have bought Lumber from a borg ,since there were plenty of Hardwood lumber whole salers in the bay area.
Regarding the quality, one only needs to glance at a stack with eyes that have seen more lumber then most.
One thing I noticed in a Home Depot in Hayward , Ca, was several units of Birch and Oak Plywood , with a large sign denoting it as "Cabinet grade".
On closer inspection , the mills grade stamp was BB which you know is several grades below what you would consider "cabinet grade" which is a misnomer if there was ever one.
I bought this to the clerks attention and was told that was what Home Depot carried in Hardwood Plywood and didn't have a clue about Lumber in general.
The only BB grade plywood I ever saw in a hardwood lumber yard was Baltic Birch and that is a very good product , though they only grade it BB.
Atleast at the borgs you can more easily pick through the lumber. My experience building a deck and fence over the last year is: if you have the local lumber yard deliver, they seam to drop off the worst stuff possible. If you let them drop off a few thousand dollars worth of Azek trim, they delievey the boards run over by a forklift, covered in dirt and girt and then stacked together to dig into the finish. If you complain, they pickup the material and replace it with more trashed material. All this with the warning upfront you will not accept damages goods. The 2x lumber comes with one edge, the other edge only half exists due to bark. Makes it more challanging to screw done deck boards with the lined up in a row.
In our area we are down to only two lumberyards plus the borgs. Its not what it used to be.
