Spray Gun Recommendation
Thomas Norton
I need another spray gun. This time I would like a Gravity Feed HVLP gun. The project is a spraying oil based enamel.
I was thinking a gravity feed gun as it would be easier to clean up than my cup gun.
So, any suggestion for a reasonably priced gun?
Thanks
Re: Spray Gun Recommendation
Danny P
I bought the spray gun from Apollo with the 3M pressurized can, that also has the liners in the cup that you just throw away when you're done. The pressurized can is great. Spray in any position without any worry of the pick up tube not sucking up product, because there is no pick up tube.
solution to "easy to clear"
Bill Tindall
Look up the 3M PPS system of disposable cups. I will have an archived post on this topic a few months back. Wonderful invention, at least for conventional spray guns. Unless you spray a lot of stuff you will never get a pay back on a new HVLP gun vs getting an "Ebay" Develbis or Binks convention gun, which is easier to use and sprays a better finish.
Re: Spray Gun Recommendation *LINK*
Hank Knight
Keep an eye on Jeff Jewett's Homestead Finishing products site. Jeff carries great products and often has real deals on his "overstocks, closeouts and used equipuent" page. I bought a closeout pressurized cup HVLP gun from him a couple of years ago at a great price. It's a fine gun that works great with my small compressor.
Hank
Homestead Finishing Products
While I bought my HVLP from Jeff Jewitt (already linked) the below outfit has a huge selection in a lot of price ranges. You can also call them for suggestions on the material you want to use. Oil enamel will need a larger tip/needle set and a descent gun to get a good finish. If you have to dilute the paint for proper atomization, consider using naptha as it will dry much more quickly than mineral spirits.
Guns Galore
Grant in Iowa
I have a Porter Cable PSH-1 and am happy with its performance and build quality. I find that I am able to make adjustments to spray a variety of viscosities and materials satisfactorily.
Indeed there are many gravity feed HVLP guns that are available at a low cost. I have looked at several and they appear to be largely the same, if not made on the same assembly line in China.
Oh, and I'd like to take the guy to lunch that decided to call the spray gun the "PSH-1". Makes it easy for me to remember and I get a chuckle every time I say it to myself. I wish my planers model number was "Grrrrrrrrr-1", and my table saws model # was "zzzzzzing-1", and my TV's model # was "blah-blah-blah-1".
FWIW,
Grant in Iowa
blah-blah-blah-1  ROFL
Jesse Cloud
