Thanks Bill Tindall.....
I read your post about using citrus juice to take a rust stain out of a plane.
I made a cutting board/drain board. It sits beside my sink and has slight sides on it with slots that sit over the rim of the sink. So, you can cut up stuff and push the scraps into the sink/garbage disposer or let things sit on it to drain into the sink. My son set a steel wok on it over night and the steel left a stain about the size of a quarter. Not a disaster, but one of life's little bummers.
I put some lime juice on it and it helped a bit but after several hours it seemed to have stopped working, so I put some salt on it as an abrasive and scrubbed the area with the section of the lime. Left the piece of lime sitting on it over night and the stain is 95%+ gone. So thanks for the tip.
Re: Thanks Bill Tindall.....
Re: Rusty Wood
Citric acid does ok as a bleach, but I've had better results with oxalic acid for rust stains. Comes in granular form at most good paint stores. Soak the spot with a mix, rub with a wood block and some dry crystals, then cover with an up-side-down plate (slows drying) overnight. Next day rinse well, rub in some baking soda to fully neutralize the acid, rinse again.
You have a plate???
I had a lime. I drink lime in my tea. I was willing to invest 1/8 of a lime in this chemistry experiment along with a few grains of salt. It was easy, it worked, it did not bleach the wood, just the stain, and I am willing to lick the spot. Not sure the salt would be good for me, but the lime is keeping me from getting Rickets. It must be working, because I don't have Rickets.
If I had oxalic acid, I might have tried that, but I wouldn't lick it.
even better vs. scurvey
paul in AZ
Right! Don't have that either, It's a miracle
Re: Plate?
Chure, gotz a wotta dem.
No Rickets? So how do youz pway croquet?
Re: Plate?
I used to play Croquet, actually made a set, but I had to quit. Was not comfortable with the idea of hitting my balls with a big wooden mallet.
Then
There's no way you want to get into a cricket match.
I'm Glad You Are Not Rickety, Barry
Sounds Like Chicken Croquet
Stop wine-ing
