We value your privacy.
Hi well its time to remove my jointer knives from a 16'' crestent jointer to have them sharpened but they are stuck. all the bolts have been removed from the cutter head still cant
seem to loosen them up. I have had them out before maybe I am not going at it the right way.
You took out the screws but did you loosen the holding clamp? Crescent heads are not like the standard heads on most jointers. You need to take a dowel or brass rod to tap down the holdin cylinders that hold the knife gibs in place. The tables slide apart to get at things easier. I typically use a fixture that straddles the head to change the knives on Crescent heads. I set the knives about 1/32" high and tap the down into place with a piece of end grain hardwood stick. Of course you have to make sure the tables are parallel to the head. One of the better jointers out there. Sort of similar to parallelogram tables but much easier to work on and adjust.
