Semi OT Planting Trees
Paul T
Hello All, I have a black cherry tree in my yard that is dropping "cherries"...about pea size. I have a clear cut area on my land...removed scotch pine plantation that was blocking the view...that I would like to plant black cherry upon. What would I have to do with the "cherries" in order to get them to grow in pots initially and then transplanted to the clear cut area? I've heard that they may have to be dried first or frozen.
TIA
Paul
Re: Semi OT Planting Trees
I don't know he requirements for black cherry, but what you are talking about is called "stratification" I think. Not sure they have to be dried, but the idea is that they lay in the environment for a while, go through a winter and then sprout in the spring. You might try collecting a few, put them in a layer of wet paper towels in the bottom of your refrigerator for about two or three weeks and then plant them just under the surface or the soil and see if they sprout.
Google Stratification.
FredD
One commonly used technique is "Cold Germination" where you take a plastic Zip lock bag , put in some dame Peat moss and your seeds and leave in the Fridge for ninety days, then take them out , plant in some potting mix where it will be warm , when the seedlings get large enough for outdoors , there you go.
If you Germinate them in the fall , by the time Spring arrives and the ground warms up , you should have some nice seedlings to go outdoors.
FredD
Re: Universal planting truth
Bill Turpin in WNC mountains
Remember to put a $2.00 tree in a $50.00 hole, instead of a $50.00 tree in a $2 hole.
Stratify and scarify
Tom Dunlap
Most seeds, especially ones from above the 'frost/snow line' need to be stratified. They have to go through cold temps to start the chemical germination.
Many hard shelled seeds need to be physically broken or opened to help the root to break out. Sometimes just a nick with a file, other times sanding off the end...be sure to do the right end, before planting.
Do a google search on planting cherry trees. You likely have Prunus cerotina...but maybe another, to find out the proper germination techniques/
'It takes 100 years to get a 100 year old tree'
'The best time to plant a tree was 10 years ago...the second best---today!'
Al Stokka - Cambridge, Iowa
Paul,
Lots of hinting at the time and process. Here, from the USDA's 1961 yearbook of agriculture entitled "Seeds" is the recommended germination treatment for Prunus serotina:
Stratify for two to three months at 33�F-41�F.
I would put a handfull, how big a handfull depends on how many seedlings you want; germination averages 63%, in a poly zip close bag with damp potting soil. Put the bag/seeds/soil in the crisper drawer in the bottom of the refrigerator (be sure to tell the wife to treat it gently and not throw it out) 'til spring. Check the bag occasionally, if you wish, for sprouted seeds and, if any, you can pot them at the time of discovery. They will be fine for quite a few weeks, though, living in the refrigerated bag.
Good luck,
Al
They grow here like weeds, in fact
Ray - Middletown, IN
I treat them as such. My wife pulls them and/or I spray them every late spring. Maybe I should put them in pots and sell them. Be cheaper than buying roundup. Also walnuts, hate to mow around them buggers in the fall.
Ray
they must germinate easily
Bill Tindall
Every place birds sit I have cherry trees sprouting. It would seem that all you would have to do would be to throw them around where ever you wanted them.
Rick in Colgate, Wi
I have a lot of black cherry trees and tried growing the seeds in pots with no luck. They do seem to sprout naturally on there own however. My understanding is that it takes about 3 years for the hard shell to soften so they can sprout. I scattered about a zillion seeds in a cut over pine plantation about 4 years ago and they are now starting to grow, guess it just takes time.
